Drag wheels/tires - Let's see them!
Old Feb 3, 2012 | 01:45 PM
  #51
GREENSIERRA's Avatar
15x10, 325 M/T drag radials
Old Feb 3, 2012 | 04:39 PM
  #52
Vortec350ss's Avatar
Originally Posted by foose04
Are you still on the factory 10 bolt?
Old Feb 3, 2012 | 04:50 PM
  #53
bmd_CL's Avatar
im pretty sure he is, i think hes got an auburn posi, but im not 100%
Old Feb 3, 2012 | 05:04 PM
  #54
foose04's Avatar
Yes sir. Running it with a Moser cover/support and ARP studs on the caps. So far so good.
Edit: Sorry and a True-Trac.
Old Feb 3, 2012 | 05:08 PM
  #55
Steve-O-08's Avatar
Foose your truck looks killer as always. Love the Bogarts. Maybe one day... haha.
Old Feb 4, 2012 | 03:27 PM
  #56
I lole the way the big aluminum girdle's look. I'm convinced they make these 10 bolts a lot stronger too. I will get one eventually. Do you think the studs make a big difference compared to the standard bolts? I like the idea of having them, thats for sure.
Old Feb 4, 2012 | 05:23 PM
  #57
foose04's Avatar
I agree man. I did the studs because I think they were like 30 bucks or so and I figured if i'm going to try and make this rear take abuse, I should do what I can.
P/N's:
MSR-7107 DIFFERENTIAL COVER
MSR-7115 MAIN CAP STUD KIT
And back on topic thanks Steve and GreenSierra you got a good looking rig man! Keep the pic's coming guys!
Old Feb 4, 2012 | 07:36 PM
  #58
2004SSS's Avatar
picking up my new 18x10's this week (same ones parish ran)
[IMG][/IMG]
powdercoated centers, re polished them , then repowder coating the entire rim clear. still have to grind , re powdercoat and rebuild my custom baer alumasport front to run these , sucks changing front brakes everytime i want to drag but the 6 pistons need 20's or bigger
going on et streets on all four corners in 305/45/18
here are my new 16x8 rims , weigh in @ 12 lbs and the hoosier 26x9.5 weigh 18lbs . 30lbs for wheel and tire is dam light and the 20"s i run for Daily status weigh well over 55lbs so its a huge difference , got it running low 12's stock and hoping for mid to high 11's with a big pulley and heat exchanger.
Old Feb 4, 2012 | 08:22 PM
  #59
P/N's:
Thanks, your truck is bad ***
Its my brothers truck and we actually just picked a 5.3 up for it today.
Gonna be a huge step down from what was in it but still be alot of fun
This motor was built for 250+ shot but never got to spray it, 470rwhp n/a on pump gas, changed head gaskets to a little over 10.1 for streetability with a carb way to small for the motor(825cfm) and only reved it to 6000 when it was built to 7000
Old Feb 13, 2012 | 01:20 PM
  #60
orange1500hd's Avatar
anyone have more pics of stock 17s with drag radials? gonna get 295/45/17 mt's here soon
