Drag wheels/tires - Let's see them!
Old Nov 12, 2018 | 08:15 PM
  #151
Basco's Avatar
Old Nov 13, 2018 | 07:34 AM
  #152
BigBlock90's Avatar
Originally Posted by LOstrolencki
thanks for the intel man, one more thing. the blazer calipers u are running on the rear, did the silerado rotors, brake lines, and bolts for the calipers work or was there any other custom fabrication besides grinidng? and on the front i noticed u still rocked a 15" wheel, did u have to swap the front calipers out too?
Originally Posted by 03regcab sierra
S10 blazer calipers are direct bolt on from stock just grind em till they clear the wheels. Front 15s work as long as u have 99-04 brakes. Bigger brakes that 05 up have will require grinding or wheel spacer
Any specific year model blazer calipers or standard 95ish and up year model? I guess we are talking front brake caliper for the blazer? I have a set of 15x10 racestars id like to put on the rear of my 99nbs and it has the disc brake rear.
Thanks for any answers on this, Jamie
Old Nov 16, 2018 | 10:49 PM
  #153
brandon6.0's Avatar
I cant remember, but im pretty sure they were front s10 brakes. The rears were drum.
I had s10 brakes on my nbs. I had to grind them alot to get them to fit. I ran them for years like tht with some steel 15x10 budget wheels.
I just switched to a complete racestar drag pack. I went ahead and did the 1320 brake brackets with 90s obs front brakes. I have alot more clearance. Like almost a 1" gap between caliper and wheels.
Old Apr 5, 2021 | 12:24 PM
  #154
madracer402's Avatar
My little beater
Old May 18, 2022 | 11:02 PM
  #155
oscargasca1221's Avatar
Registered User
they should fit on all 4 unless you have a drop kit on the front
Old May 19, 2022 | 05:59 PM
  #156
terravast4's Avatar
Old May 22, 2022 | 02:07 PM
  #157
smokinlmm's Avatar
That looks bad ***...
Old May 28, 2022 | 04:51 PM
  #158
terravast4's Avatar
If you are refering to my truck, thank you!!!
Old May 30, 2022 | 05:57 AM
  #159
smokinlmm's Avatar
I was sir! Pretty work!
Old Jun 10, 2022 | 12:37 PM
  #160
ALL ULL C's Avatar
Certainly makes me re-consider the 5-lug swap.
What is the setup spec wise if you don't mind sharing.
Originally Posted by terravast4
