door handle pulls
Old Jun 10, 2005 | 11:48 PM
Searching4Sierra's Avatar
Default door handle pulls
i recently got ahold of some escalade door handles and i want to transfer the chrome part of the handle over to my handle buckets. does anyone know how to separate the part you pull to open the door from the bucket? please help.
Old Jun 11, 2005 | 07:07 AM
onelow04's Avatar
I have done this many times. Take out handle, flip over you will see a pin on one end of the handle. Take a dremel with a cut off disk on it and and cut off the flared end then you can take a small screwdriver and push out the pin. I always put it back together with a nut and bolt the size of the pin. On the other side of the handle it has a black plastic pin holding the spring assembly. the pin has to slide out push the ears on the plastic pin together and slide the pin out of the hole and transfer to other handle. p.s. be sure to look at how the spring is setting it is easy turn it around.
Old Jun 11, 2005 | 11:32 AM
thank you, i knew it looked like there was some cutting involved.
Idryfly5
Sep 2, 2022 08:55 PM
lucas287
31
Jan 12, 2021 06:18 AM
chvy=power
Sep 8, 2015 11:06 AM
RoidedSS
Aug 11, 2015 11:51 AM
