denali front end conversion questions
Old Nov 20, 2004 | 02:48 PM
TwoFast's Avatar
Default denali front end conversion questions
I know this topic has been beaten to death but I can't really find the answers to some of my questions. First, I found a denali front bumper cover on ebay http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW Is that all I need bumper wise? Also is this all I need as far as the conversion: front bumper cover, headlights, parking lights, grille shell? Also I found this http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Do I need new bumper bracket supports for the denali bumper? Is this a simple bolt on installation? Do all of the headlights and parking lights plug right in with no modifications and also do they mount the same way/ basically does everything fit like the sierra does? IS THERE ANYTHING I'M FORGETTING??????? thanks
Old Nov 20, 2004 | 02:52 PM
CHAGO's Avatar
all the lights and such should be plug and play.
Not sure about if you'd need to change out the fenders or not, but probably not.
The bumper supports and brackets you'll most likely need as well.
I'd tell you to ask Chingon, who did the swap, but he's backpacking through Europe with his gay pal MaCaDaYear
Old Nov 20, 2004 | 03:17 PM
bodyguard6799's Avatar
I'm doing the conversion on my 01 Seirra right now. Your fenders and hood will work. Your corner lights wont. You need a front bumper insert called a bar p/n-015060470. next bumper cover fascia-p/n-012479754. grill-p/n-015764319. filler that goes in between the bar and fascia (foam)-p/n-088937235. the 2 fillers that go under the light bracket-p/n-015046666 & 015046662. These are all GM p/n's. I think thats it, all the bolts that hold your factory bumper on are the same, and the brackes that hold the ends of the bumber (sides) are the same too. you're going to need 13 push clips to hold the bumber cover to the insert, I dont know the p/n's for those. Other than the fog lights and the small valence grill on the cover, I think thats it. I hope this helps, Good luck!!
Old Nov 20, 2004 | 04:53 PM
TwoFast's Avatar
So do I need the brackets that I listed in the first post that I found on ebay? thanks for all the info.
Thanks also ILLNALI
Old Nov 20, 2004 | 04:57 PM
one03sierra's Avatar
Formerly one92rs
Talking
no the brackets that you are looking at on ebay are for a 99. they were the old style denali.
Old Nov 20, 2004 | 05:09 PM
TwoFast's Avatar
Yeah thats what I was just thinking now that I read his description more closely. Thanks 02 Denali.
Old Nov 20, 2004 | 06:16 PM
rayce08's Avatar
you need the crash bar that goes under that denali bumper cover . its what bolts to your truck as the bumper then the cover slip over it and is held on with push clips . the fog lights and lower grill bolt to the crash bar , its heavy and the most exspensive besides the grill itself . the headlights are the same and youll need denali corner lights and denali side fillers .fog lights and head and cornerlights use all your plugs . everything bolts on within minutes . if you had everything assembeld you could swap frontends in 30 miniutes . i did my 2000 @ 2002 . i bought my covers from the same guy on ebay and there great but dont think you will not have to paint them if your buying the color you need , i did , both black and had to have painted . i have everthing you or anyonelse needs for a complete conversion cheaper than you will ever buy it anywhere else in the forsale furum.
Old Nov 20, 2004 | 07:47 PM
TwoFast's Avatar
rayce08, You have all the parts for sale?
Old Nov 20, 2004 | 09:25 PM
rayce08's Avatar
yea , i have the grille with billit insert (good one 110$ , not a cheap one) bumper assembly complete with foglights , clear corner lights and both side fillers 650$ but negotionable ! all you would need is to paint the bumper white and get some denali lights if you dont allready have some.
Old Nov 20, 2004 | 10:58 PM
paw's Avatar
paw
· 15046662 - Filler between grill and bumper - LH
· 15046666 - Filler between grill and bumper - RH
· 15150999 - Parking lamp - LH
· 15151000 - Parking lamp RH
· 15764319 - GMC Denali Grill
· 15166756 - Headlight - LH
· 15166757 - Headlight - RH
· 12479754 - Bumper cover
· 14093088 - Retainers (7 needed)
· 15149708 - Retainers (12 needed)
· 15153490 - Insert
· 15060470 - Impact bar
· 16516335 - Fog lamp Assembly - LH
· 16516336 - Fog lamp Assembly - RH
· 15059859 - License plate bracket
Heres my yukon with the denali conversion. *notice impact bar*
Attached Thumbnails denali front end conversion questions-000_0211.jpg   denali front end conversion questions-000_0268.jpg
JordanH
Feb 28, 2017 07:22 PM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
mrgrim
Jul 8, 2015 08:12 AM
