damn rattles
Old Mar 18, 2009 | 06:36 AM
white lightning SS's Avatar
There are new design rear window latches to fix the 1/4 glass wind leak. The crackling noise is probably from the clip in screw retainer in the inside sheet metal. Should be able to tighten it or cover ir with anti-itch tape.
Old Mar 18, 2009 | 11:32 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by white lightning SS
Clean all your weatherstrips and soak them down with WD-40 or get GM dielectric grease and paste it on. This is not a permanent fix but cleaning and maintaining these will keep the noise away for 6-8 months. I do this for customers and explain what is happening. Slip stick of weatherstrips.
At Lexus we call the weatherstrip noise "rubber itch", our doors do it too. Our tech line recommends that we clean all of the silicone of the weatherstip and body with 3M general purpose adhesive remover, and treat the weatherstrip with Kent Dry-Lube. Seems like I have a 50/50 sucess rate with that. I may try the dialectric grease trick though...
jscherbs
Mar 24, 2017 07:20 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Raiderjim
14
Sep 26, 2015 10:18 PM
97_ek
Sep 23, 2015 09:16 PM
