Brightening Aluminum
Old May 14, 2007 | 02:02 PM
kbracing96's Avatar
Default Brightening Aluminum
Hey guys, I have a 04 5.3 I'm putting in my dads 72. The motor cam from somewhere that had lots corrosive weather and it looks really bad. Any suggestions on what to clean it with that will brighten it up and look more like new aluminum?
Old May 14, 2007 | 02:27 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The '04 5.3's are Iron blocks/Alum heads. I would give it a good cleaning using your favorite engine cleaner taking care for the electronics, intake, etc.
Old May 14, 2007 | 04:24 PM
kbracing96's Avatar
Ya the heads and accs are what look really bad on it. A lot of corrosion and dingy looking. I just want to know if you guys know of some good cleaners to make it look better (more like the turbo ).
Old May 14, 2007 | 06:17 PM
Phantom's Avatar
11 Second Club
i use simple green
Old May 14, 2007 | 11:42 PM
RedHot04's Avatar
Try a scotch bright pad on the the cast alum. and some Mother's alum. polish on the valve cover and heads. Both will work wonders.
Later
Old May 18, 2007 | 03:09 AM
RedHot04's Avatar
Well, did you get'er all cleaned up?
Old May 18, 2007 | 10:06 AM
LS1GMCTruck's Avatar
Lightbulb Aluminum brightener
What you need is any aluminum cleaner/brightener that contains hydroflouric acid. Spray it on the aluminum parts with a hand spray bottle, wait a few minutes & then rinse. No brushing is required. A second application is usually required, but completely dry the engine again(compressed air) for best results. Do not dilute the product. Products that have hydrofouric acid in them are Mag wheel brightener, marine hull cleaners, etc... A good automotive parts store or automotive paint supply house or marine store can be your source. Do not get this product on your mag wheels or anything that is anodized, as it will remove it. Use throw away rubber gloves, preferably Nitral rubber gloves, to avoid getting it on your hands. Hope this helps.
Old May 18, 2007 | 11:07 AM
kbracing96's Avatar
That's the kind of stuff I was thinking about, I just didn't know what it was called. I'll see if I can find some.
Old May 18, 2007 | 02:42 PM
UBLUZIN03's Avatar
Double zero steel wool and any kind of metal polish...
Old May 18, 2007 | 03:09 PM
TurboGibbs's Avatar
Go to the parts store and get some Mag wheel cleaner, I know Eagle One makes some. It is a light acid. I use it all the time on rough aluminum.
