Bogart mounted
Old Apr 11, 2010 | 10:10 PM
  #21
AustinDesigns's Avatar
Can you run the Bogart 15's up front on a 05+? I know they will fit on the pre 05's, but didn't know if they would work on the newer ones being they swapped to bigger rotors up front.
Old Apr 11, 2010 | 10:14 PM
  #22
LsxCody's Avatar
looking good!!!
Old Apr 13, 2010 | 02:32 AM
  #23
Blown06's Avatar
8 Second Truck Club
I wish I had leafspring clearance like that. I'm guessing the drumbrake rears are actually a little narrower than the disk brake rears. Does that sound right?
Old Apr 13, 2010 | 05:34 AM
  #24
blown02408's Avatar
02 w/ lowest mileage 2800
Not sure, but could be. I'm narrowing mine 2 1/2 inches per side, which is a disc brake setup, and running a 4 1/2" backspace wheel. Which equates to a 7" backspace on a stock setup. I should end up with about a 1/2" spring clearance with the 325/50R15 tire, if my math is correct.
Old Apr 13, 2010 | 03:51 PM
  #25
1BADAZZSS's Avatar
You know I remember you and I discussing that. I am gonna measure wheel mounting surface to wheel mounting surface on my rearend this weekend and see what I come up with. Maybe we can get someone (aka you ) to meaure there truck with drums and we will compare measurements.
Old Apr 13, 2010 | 07:25 PM
  #26
fastnblu's Avatar
Originally Posted by 1BADAZZSS
2-15x10's, 2-15x5's bolted d10's, center caps front & rear, lug nuts, +shipping. $1860
They look great! Direct from Bogart, right?
Biggest D/R mt makes. 325/50r15. sticks out a bit, but thats fine. 4/6 drop will commence next weekend, then finish tune.
Mounted on Broke10's 4/6 drop silvy.
6.5" Back spacing, section width 13.1". leaf clearance bout an 1"
http://www.summitracing.com/parts/MTT-3757R/
Size:  96.5 KB[/QUOTE]
Originally Posted by skeet
15s up front will fit fine, the back if youre wanting to go with 15 then you would need to swap to a s10 caliper cause of the banjo bolt being on top ( the s10's are on the back side ) yes they would need to be grinded
Rich will make any rim to your liking ...
Really?
Old Apr 14, 2010 | 01:29 AM
  #27
Blown06's Avatar
8 Second Truck Club
Let me know.
Old Apr 14, 2010 | 01:48 AM
  #28
Spoolin's Avatar
GFYS and STFU
Take some better pictures!!! Looks good though!
nabozny21
Oct 17, 2015 07:47 PM
thewrx
Oct 6, 2015 10:59 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
DrX
Sep 29, 2015 04:31 AM
