Best Drop Kit
Old Dec 9, 2005 | 12:19 AM
jakebdb56's Avatar
Default Best Drop Kit
Okay so I'm looking around and I"m trying to find a good drop kit for a 2006 ECSB 2wd. 2006 and 2005 are supposedly the same, so keeping that in mind which kits has anyone used and liked? I've seen many different types.
It looks as if the GroundForce 2/4 drop does the job, but I'm worried that maybe the torsion keys aren't as good as getting another kit that replaces the LCA's.
From what I've seen on other forums like BlazinLow there's a lot of guys using the Belltech kits. They seem to have a good reputation for being complete and including good instructions.
If anyone wants to post a pic of their truck that'd be nice so I can get to see what the difference might be between a 2/4 and 2/3, I know it's an inch but it might make a big difference. Thanks for the help again
Old Dec 9, 2005 | 06:35 AM
smooth sierra's Avatar
MCGAUGHY'S......They won an award at SEMA from GM on their drop spindle kits. I went with their 2/4 spindle drop and I have been very pleased.
Old Dec 9, 2005 | 07:05 AM
leochevy2001's Avatar
i also have the mcgaughy's 2/4 kit with drop spindles and it rides great. i just need to replace my stock shocks.
smooth sierra, i don't know if i asked you this or not but did you have to use shock extenders for the rear?
Old Dec 13, 2005 | 03:56 PM
wes00silverado's Avatar
I'm looking to get a 2/4 kit too. Where did you guys buy yours at and how much were they?
Old Dec 13, 2005 | 06:36 PM
ebay $355 to my door....brand new
Old Dec 13, 2005 | 06:43 PM
bluecajun5.3's Avatar
11 Second Truck Club
i did the hotchkis springs up front and the beltech shackles/hangers in the rear. still running stock shocks. the ride is almost stock like but i do need a c-notch...
Old Dec 15, 2005 | 09:42 AM
I was looking at the McGaughy kits and I'm wondering which one I need. There are 2 2/4 kits one with a C footnote and the other with a T.
C says:
"Spindles include call joint spacers without and flippng fo that 16" or larger rims can be used. You can only use these spindles on coil spring front end, 2WD, 1/2 Ton Chevy or Gmc trucks."
T says:
"Must use 17" or larger wheels in orger to use the spindles. Factory 17" wheels will work with a slight modification, aftermarket cast 17" wheels likely wont work.
My question is that I'm running 275/60/17, a pretty meaty tire, so do I need to go with the C or T kit? And since the C kits works with 16 or larger why do they even need a T kit?
Old Dec 15, 2005 | 02:48 PM
C says:
T says:
I believe the T's are the preferred spindles. Those are the ones I have on mine. I would think it would be awful tight with a 17" wheel. The lower ball joint stud would definitely have to be cut. the ball joint nut is recessed inside the spindle though.
I have 20" wheels so clearance was not an issue for me
Old Dec 15, 2005 | 06:41 PM
99Silver6.0's Avatar
Hotchkis for handling period.
Old Dec 15, 2005 | 06:45 PM
i like the hotchkis springs up front. the reason why i went with them is because i like to run my factory wheels and can also run my 20's with them...
