Anyone add a rear sliding window in 99-02?
Seems like GM stopped optioning that out in the NBS due to not being able to keep a seal, so I've been told. It looks like they have since come back with it on the 03+. Just wondering if anyone has added a read slider to those non years with success, ie no leaking.
Thanks guys,
Andrew
Thanks guys,
Andrew
Thanks guys,
Andrew
Thanks guys,
Andrew
CRL slider,
had it for 2 summers,
no complaints
I think it was about 180 plusshipping and $40 to have my guy glue it in.
I'll pm you the link,
I've had the CR Lawrence sliding rear window in my truck for about 4 or 5 years now, and it's been great. It was installed under warranty at the dealership after 3 factory sliding rear windows cracked in the upper corners of the plastic window frame (water would pour in...first one cracked right before a hurricane!). Seems if GM just made the frame out of metal instead of plastic they wouldn't have had a problem.
The CRL window is pretty much the same configuration that the stocker was, except it slides behind the driver whereas the OEM one slid behind the passenger. It looks stock and works nicely
Thanks guys,
Andrew
Thanks guys,
Andrew
When I first got the truck (used), it had a very similiar slider that leaked a bit, so I took it under warranty and the dealer/glass shop replaced it with an extremely cheap split slider.
Well, I bitched and the dealer agreed that it was a complete POS window, so I now have this CRL one.
CR Laurence makes power sliders, but it slides that middle vent over not the whole window down.
http://www.crlaurence.com/ProductPag...6.html?Origin=
Corvette454l88
Sep 1, 2016 01:24 AM
