295/75/16 anybody tried it?
Debating on 305/70/16 or 295/75/16 tires.Just would hate to get the 295's and they rub real bad.. Dont have a body lift but I do have the the torsion bar cams and got the front sitting a bit higher than the rear. Anybody ever run this setup???
Will these be mounted on the stock rims? Your gonna need an 8" rim for those 305's. I wouldn't even put the 295's on a stock 7" rim - minimum specs say 7.5".
Do you have 33's on there already?
I wish I had 33's already, just 285's
Originally Posted by chevymec
Stock rims. Actually I have mounted a set of 305's on stock rims .
You might have already seen this, but moregrip put 32's on his truck in a 305 width (all be it with 20s, though): https://ls1tech.com/forums/showthread.php?t=249496
Again, not stock rims, but the diameter and width are there for you.
Originally Posted by DanaliHD
I've got 295 Nitto Terra Grapplers on my HD and they rub BAD. They look stupid on the stock rims too, I think. Bad decision. they bow out too much. i need wider wheels. i say stick with 285's.
Originally Posted by KeukaZ71
what is the largest size tire you can get on stock rims and suspension (with no torsion bars cranked up)?
i have 265/75/16, you know, the stock tires
