285/75/16 on a stock 2500HD
Old May 31, 2003 | 11:08 PM
GMC2500HD's Avatar
Default 285/75/16 on a stock 2500HD
I have an 03 2500HD 4x4 GMC that is stock height. I did crank up the torsion bars to make it level in front. My question is could I fit 285/75/16 on 8" rims under the truck with out a lift? I am going to take it to a body shop and see about trimming a little of the front bumper for more clearance. The washer fluid resevoir seems to be under the battery box that may be an issue also if I get the truck twisted up. Any feedback would be appreciated.
Old May 31, 2003 | 11:59 PM
silent1's Avatar
Default Re: 285/75/16 on a stock 2500HD
I have a 2001 1500 4x4 and run 305/75 R16's on stock rims w/ no problems, you should be just fine.
Old Jun 3, 2003 | 02:02 PM
1BADHD's Avatar
You will be ok. I ran that exact combo for 36000 miles before my lift. All you have to do is trim the lower air damn a little with a dremel tool. And maybe tie back the inner liner on the driverside. Depends how much you twist teh truck up!
thunder550
Oct 8, 2015 04:53 PM
Matt C.
Aug 1, 2015 01:25 PM
oharajo
Jul 18, 2015 09:24 PM
76k10chase
Jul 17, 2015 01:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
