2" drop spindles or lower control arms
Old Jun 11, 2004 | 05:55 PM
  #21
blk03's Avatar
You think a 2/4 would be too much if I have 285/60/18s? Anyone my area know of a good shop that could do the install if I chose not to?
Old Jun 11, 2004 | 09:37 PM
  #22
OUT2WIN's Avatar
I have a 4/6 and no carrier bearing bracket. They sent it to me but I have little vibration. I would have used it when I had the djm shackle and hanger cause it vibrated a lot then. Flip kit fixed the vibrating driveline. I used to deal with Stylin' Concepts for everything but Godfather Customs is less expensive and seems to know their stuff better.
Just my $.02
Old Jun 13, 2004 | 05:12 PM
  #23
blk03's Avatar
Would I need anything extra if I went with the DJM 2'' rear shackles? Or would be the McG be a better route?
Old Jun 13, 2004 | 10:28 PM
  #24
SierraSport's Avatar
Originally Posted by leochevy2001
djm lower control arms. belltech spindles reduce your turning radius.
That is true ..
I have DJM 4/6 and I love it ..
Old Jun 15, 2004 | 01:34 PM
  #25
leochevy2001's Avatar
Originally Posted by Mac8
Guys, I just called Mcgaughys and they said their deluxe 2/4 drop(drop spindles, hangers, shackles) is designed to use the stock shocks and already has the pinion angle modified in the hangers and shackles. So, no axle shims are required. To be able to use the stock shocks will save $100. Plus, the kit is only $384. Seems to good to be true. They do have a patent on their shackles and have several years of R&D.
I called them myself to find out how much their drop would be and to find out if I would need a carrier bearing kit. They told me that it would cost $438+shipping (extended cab) and that I might or might not need the carrier bearing kit and I wouldn't need drop shocks. They told me that of all the drop installed on these trucks that only one needed the carrier bearing kit. I also asked if the drop spindles would work with 1" drop shocks because I want to drop mine 3/4. They told me yes, that the coils will work with the drop spindles.
jacobrobertson2010
Aug 17, 2015 06:20 PM
Allgonoshow
Jul 29, 2015 04:21 PM
Kaldar
Jul 27, 2015 06:42 PM
lxcoupe
Jul 8, 2015 05:49 AM
