2" drop in rear?
Old Apr 20, 2003 | 06:15 PM
4.8bowtie's Avatar
Default 2" drop in rear?
my truck sets 3" higher in the *** than the front and i want my truck to set more level.there is a 2" spacer between the springs and the axle.just wanted to know if was as simple as pulling out the spacer?looks like if i did pull it out id have to get different ubolts because there is not enough threads on them after the spacer is out.anyone done this?any problems?easy job? THANKS
Old Apr 20, 2003 | 07:17 PM
Ajax's Avatar
Default Re: 2" drop in rear?
The quickest & easiest method to lower your truck 2" in the rear would be to replace the shackles at the rear of the leaf springs. They are pretty cheap too. It only takes about an hour to do. Any company that sells after market parts for our trucks should carry them.
Old Apr 20, 2003 | 07:42 PM
4.8bowtie's Avatar
yeah i could always do that i think its only 50$ or so. but to pull the spacer out would do the same thing for nothing
Old Apr 20, 2003 | 10:05 PM
If you are talking about what I think you are it's welded to the rear-end and has a guide hole for the springs. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 20, 2003 | 11:35 PM
FILE's Avatar
What about dearching the lowest of the leaf in the leaf spring. One of my friends had that done in Mexico for $25. They were able to lower his truck 2 inches from the back and there was no change in ride quality. I certenly think its worth if you ask me. Anybody has any input or experiences on this?
File
Old Apr 21, 2003 | 12:23 AM
I did the 2 inch rear drop using the shackles... some of the best 50 bucks I've ever spent! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> It really looks much better with the truck being levelled out, especially if you have some bigger wheels. It helps to have air tools for the install though, it got a lil tricky at times using opposing wrenches to tighten/loosen the bolts. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Good luck!
-Kurt
Old Apr 21, 2003 | 02:18 AM
blacknight02's Avatar
I've got some 2 inch drop shackles for sale if ya want them. $50 and there yours.
SLOPONY
20
Oct 18, 2016 06:05 AM
black03rcsb
Sep 1, 2015 10:17 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Ketis
Jul 23, 2015 12:37 PM
