07 Tahoe Wheels & Backspacing
Old Sep 14, 2007 | 08:20 AM
SCIV's Avatar
Default 07 Tahoe Wheels & Backspacing
Does anyone know what the correct backspacing is for 22" X 9.5" wheels? I see them listed with like +40mm and +12mm? I don't understand that stuff. I assume the +40mm would stick out, so the +12mm is what I would be looking for? I DO NOT want the wheels to stick out past the fender.
This would be on an 07 NNBS Tahoe, which I would think is the same as all the 99 & up NBS?
TIA,
S.C.
Old Sep 14, 2007 | 09:02 AM
Allgonoshow's Avatar
stock for nnbs is 30 offset and 6" backspace
pre 07 was 18 mm and 5.5
Old Sep 14, 2007 | 09:46 AM
02BlueStepside's Avatar
The more offset the more the wheels tuck into the fenders. You will want to go with a +40 if you don't want them to stick out.
And the 07+ trucks/suvs use a larger offset than the pre 07s to tuck. A lot of the pre 07 guys are actually using the cast 07+ wheels since they are cheaper than billets and still tuck.
Old Sep 14, 2007 | 10:49 AM
SCIV's Avatar
Thank you very much guys!
Old Sep 14, 2007 | 03:37 PM
the 07's have a wider track, hence more offset needed to keep the wheels inside the
fenders
Knightcrawler
Jul 20, 2016 03:29 PM
thunder550
Oct 8, 2015 04:53 PM
mitchellmade
Sep 27, 2015 08:25 PM
Alco
Sep 4, 2015 04:08 PM
WhoAteMySoup
Aug 20, 2015 09:52 AM
