03 Sierra to 03 Denali front end???
Old Oct 12, 2005 | 06:57 AM
creederado's Avatar
Default 03 Sierra to 03 Denali front end???
Does anyone know if the frame horns/radiator support are the same between each. Not sure how envolved a swap would be.
I did a search but most swaps were on the 99-02 gmc's?
Thanks,
99-02 Yukon/Sierra to Denali Front End Conversion
# 15046662 - Filler between grill and bumper - LH
# 15046666 - Filler between grill and bumper - RH
# 15150999 - Parking lamp - LH
# 15151000 - Parking lamp RH
# 15764319 - GMC Denali Grill
# 15166756 - Headlight - LH
# 15166757 - Headlight - RH
# 12479754 - Bumper cover
# 14093088 - Retainers (7 needed)
# 15149708 - Retainers (12 needed)
# 15153490 - Insert
# 15060470 - Impact bar
# 16516335 - Fog lamp Assembly - LH
# 16516336 - Fog lamp Assembly - RH
# 15059859 - License plate bracket
Old Oct 12, 2005 | 08:21 AM
ZDEN's Avatar
i did the swap on an '02 i had. i now have an '05 sierra denali i don't see why they would make two diff frames so it should be the same. all the parts look just like they did on the '02.
Old Oct 12, 2005 | 10:58 AM
Fogle07's Avatar
its the same. your about to spend some money if your going with oem parts. might want to call a couple junkyards for some of it.
Old Oct 12, 2005 | 11:15 AM
creederado's Avatar
Thanks,
I thought maybe they changed the frame horns with the updated front end from 02-03 Sierra,
As far as parts $, I've Got that taken care of,
Old Oct 12, 2005 | 11:18 AM
Fogle07's Avatar
pm me if you need any parts then. i might can get you a pretty good deal
Old Oct 12, 2005 | 11:46 AM
creederado's Avatar
Ok, Thanks
Should be deciding on the swap pretty soon, Looks like know one is interested in buying My GMC.
Old Oct 12, 2005 | 05:44 PM
ZDEN's Avatar
check ebay also you can get good deals on some the parts.
Old Oct 12, 2005 | 09:31 PM
Hey Creed--did you sell the step side?
Old Oct 13, 2005 | 02:34 PM
creederado's Avatar
No Sir,
I have been driving My Step Side alot, The Nitto 305 are pretty worn down I just havn't it at the track since the spring. Its gets the same MPG as the Sierra.
My GMC has been in the garage all covered up for the last two months.I wanted to sell it to get rid of payments and than buy a **** box for the winter.
But it looks like I may keep it and found a decent deal on a denali front end locally.
I love the GMC but it does hit me pretty hard evrymonth especially when i don't use it for work.
Old Mar 12, 2008 | 07:09 PM
03GMC's Avatar
Blah 02
JordanH
Feb 28, 2017 07:22 PM
5.3Caprice
Nov 7, 2015 08:56 PM
chacho44
14
Jul 25, 2015 01:47 PM
Ammadien
Jul 22, 2015 08:50 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
