03' GMC grill on 00?
Old Sep 30, 2003 | 07:04 PM
STUB25's Avatar
Default 03' GMC grill on 00?
Just wondering if this would work? Drove thru the local lot yesterday to see if things are the same and everything is the same. The only thing that is diffrent is the grill itself! ANyone with experince...
Old Sep 30, 2003 | 11:52 PM
graygmc's Avatar
Default Re: 03' GMC grill on 00?
are the front bumpers the same?
Old Oct 1, 2003 | 07:23 AM
Scream's Avatar
MOOBIES Moderator
The front bumper, air dam and grille are all different. The headlights and turn signals are the same.
The bitch about doing this swap is that the frame horns changed for 2003, so you would have to fab up some brackets to make it work.
I think that it would be worth it, and I wanted to do the swap but have already started collecting parts for a Denali front end. Good luck!
Old Oct 1, 2003 | 01:54 PM
graygmc's Avatar
hey scream do you happen to have a parts list for all the parts the swap would take.the denali swap that is.
Old Oct 1, 2003 | 03:00 PM
Scream's Avatar
MOOBIES Moderator
These part numbers might be a little old, but here is a complete list:
Yukon/Sierra to Denali Front End Conversion
# 15046662 - Filler between grill and bumper - LH
# 15046666 - Filler between grill and bumper - RH
# 15150999 - Parking lamp - LH
# 15151000 - Parking lamp RH
# 15764319 - GMC Denali Grill
# 15166756 - Headlight - LH
# 15166757 - Headlight - RH
# 12479754 - Bumper cover
# 14093088 - Retainers (7 needed)
# 15149708 - Retainers (12 needed)
# 15153490 - Insert
# 15060470 - Impact bar
# 16516335 - Fog lamp Assembly - LH
# 16516336 - Fog lamp Assembly - RH
# 15059859 - License plate bracket
The main pieces are the grille, the turn signals, the impact bar and insert, the fog lights and the fascia. I have been riding the fence on whether or not I wanna sell what I've got (fascia, clear turn signals, one fog light.) If you're interested, lemme know!
SlvrSierra4.8
Oct 1, 2015 09:42 PM
TAPyvehc93
Sep 17, 2015 10:10 AM
Roody0209
Sep 17, 2015 09:06 AM
pewter00
Sep 14, 2015 09:17 PM
sprayed99
Sep 14, 2015 12:36 PM
