Racing and Kills Forum Be smart and safe!
stock 4.8 catching tuned 5.3
Old Jun 5, 2010 | 09:16 AM
outlawz2004's Avatar
Originally Posted by Mud slinger
My buddies stock ECSB z71 will pull me by half a truck or so in third gear. I have a tune and headers, but I'm also on heavy 18s and 33s. Race him from a dig or 20-30, You should pull away pretty easy then.
That would actually result in him getting beat most likely. It takes more to get those big tires moving. I know my 4.8 from a 20-30 roll is pretty stout.
Old Jun 5, 2010 | 12:13 PM
cjsierra's Avatar
I would think that outlaw would be right about the dig but I have raced him from a dig before with no tune with the same tires and everything and we were neck and neck.
Old Jun 5, 2010 | 04:59 PM
fastlt1's Avatar
12 Second Club
Wieght, gears, and tire size. If you had the same gear ratio to tire size as he did or alittle lower, it would be a better race letting your power over come the wieght disadvantage.
Old Jun 6, 2010 | 01:19 PM
cjsierra's Avatar
What mods would it take to be able to beat him in that situation? Besides new tires for weight reduction. Would LT's be enough or would I need more? Maybe a stall?
Old Jun 6, 2010 | 01:26 PM
black04's Avatar
Gears or stall would work.
Old Jun 6, 2010 | 05:59 PM
fastlt1's Avatar
12 Second Club
Lowest gears he could have stock is 4.10s. So 4.56s would be equal with your tires. But if he has 3.73s it would be 4.10s. I'd probably go 4.56s just in case latter you wanted to run 33s or 35s. A higher stall is really only going to help you from a stop out of the hole. I'd try gears first. I felt LT headers at top end more. So if he catches and starts pulling you after the hole shot then headers.
Old Jun 6, 2010 | 09:40 PM
Your 4x4 might also have 3.42's. If both trucks have the same gears, his lower HP, will still overcome the power-to-weight ratio better than yours.
Old Jun 6, 2010 | 10:05 PM
cjsierra's Avatar
thanks for all the replies. Indigo, do you know what gears your z71 has?
Old Jun 6, 2010 | 10:39 PM
cdub81's Avatar
look in your glove box for the white sticker with all the numbers on it blah blah blah anyways it will identify what rear gears it came from the factory like mine says gt5 which is a 4.10 there is a link somewhere here on pt net that somebody posted that will give u the codes and what gear ratio it stands for
Old Jun 6, 2010 | 11:03 PM
cjsierra's Avatar
thanks for the help cdub
