stock 4.8 catching tuned 5.3
That would actually result in him getting beat most likely. It takes more to get those big tires moving. I know my 4.8 from a 20-30 roll is pretty stout.
Lowest gears he could have stock is 4.10s. So 4.56s would be equal with your tires. But if he has 3.73s it would be 4.10s. I'd probably go 4.56s just in case latter you wanted to run 33s or 35s. A higher stall is really only going to help you from a stop out of the hole. I'd try gears first. I felt LT headers at top end more. So if he catches and starts pulling you after the hole shot then headers.
look in your glove box for the white sticker with all the numbers on it blah blah blah anyways it will identify what rear gears it came from the factory like mine says gt5 which is a 4.10 there is a link somewhere here on pt net that somebody posted that will give u the codes and what gear ratio it stands for
