ZL1 Colorado: take 2
Old Jun 12, 2020 | 11:30 AM
  #141
tjmath's Avatar
Who needs a hood latch. Run it like Hector with out a hood. Or just pin it.
Old Jun 12, 2020 | 06:10 PM
  #142
Shaggy2dope's Avatar
Originally Posted by smokeshow
I can grab the turbo shaft at idle and stop it, and it stays stopped until I rev it back up.....
Must have been spinning awfully slow to have the ***** to grab onto it!
Any concerns with the flow rate of that air filer?
Old Jun 12, 2020 | 09:10 PM
  #143
smokeshow's Avatar
Mod with training wheels
Yeah it moves pretty slow at idle. That air filter is just for tooling around. I have a turbo guard for racing and will probably look into a higher flow filter solution eventually.
Old Jun 15, 2020 | 07:19 PM
  #144
smokeshow's Avatar
Welp, current issue preventing me from driving is a leaking power steering system. My stock power steering reservoir is on permanent backorder, so I had to try to modify a solution for an aftermarket tank to press-in to the pump but it leaks. Next best thing is the same exact pump, but something with threads and not a shitty o-ring insert. Anybody know of such a solution?
Old Jun 15, 2020 | 09:49 PM
  #145
Atomic's Avatar
I have a gauge for that
You dont need power steering, just get a bigger steering wheel, like one from an old bus with the **** handle and all
Old Jun 18, 2020 | 01:48 PM
  #146
1FastBrick's Avatar
Custm2500's Rude Friend
Pull the fitting and get a fitting with threads. Then do a remote tank set up.
Old Jun 18, 2020 | 02:12 PM
  #147
smokeshow's Avatar
It's an o-ring fit, Joe!
I've literally been waiting for you to step in and solve this problem for me. You have that obscure knowledge about these things.
Old Jun 18, 2020 | 02:25 PM
  #148
1FastBrick's Avatar
Isn't the fitting in the pump screwed in? This is how it appears in the picture above.
Old Jun 18, 2020 | 02:40 PM
  #149
smokeshow's Avatar
The pressure side is, yeah. But the feed side is my issue. It's a press in o-ring fitting. I need a pump with a threaded or barbed fitting, really.
Old Jun 18, 2020 | 02:43 PM
  #150
1FastBrick's Avatar
Time to break a few eggs to make an omelet as they say.
Try pulling it out. Other wise, have a fitting made that will press in there.
