Z06 Brake up grade pics
Well, they're on...alittle upset though. Come to find out the GMC decladded wheels hit the calipers face. Had to go out and buy spacer plates. Took a 1/2 inch to clear. Monday I'm going down to a local wheel shop and having customs spacers made that are hub centric.
Other then that, the pedal is the firmest I've ever felt on a truck. Only thing I've felt more firm is my dads corvette brakes. Have to season the rotors then bed the brakes. So no heavy braking for a week. Install was pretty straight forward if you have any mechanical abilities. Thanks to Rudy for the caliper brackets with supplied hardware, fit perfectly. Not a very cheap swap, but definitely worth it for the looks and added stopping power.
That's cool that you got the results with just the fronts.
I've been thinking about doing the same myself (just the fronts) but as you said this isn't exactly a cheap mod. It's probably $1300-1400 or so all said correct?
Calipers (2 fronts) - $685 brand new on Ebay for the pair
Caliper Pins -$20 on Amazon
Rotors - $272 Each on Summit
Caliper brackets - $150 from Rudy
Brake Pads (Hawk Hps 1 piece) - $200 on Summit
Custom made wheel spacers - $150
Now, you can save money with rotors and pads. I like to spend a little extra and get what i know ill like. I like to do it right the first time. I already had SS brake lines so im not gonna add that into the cost.
