Walbro 450 Install (in progress)
Old Mar 14, 2015 | 11:14 AM
  #41
George C....'s Avatar
Formerly ScreamingL
got ya cause the stock ff pump would support 550 on gas as why i was wondering
Old Mar 14, 2015 | 11:23 AM
  #42
DrX's Avatar
DrX
Originally Posted by Byrdman11
Not that the high pressure relief. But I think you know that now. Just making sure.
Tomāto/Tomäto
It's both. It functions as the regulator if the FPCM or FP sensor goes out and the pump gets full voltage, so it must be calibrated to maintain a pressure just over the pressure that the FPCM tries to maintain.
Old Mar 14, 2015 | 01:25 PM
  #43
TAPyvehc93's Avatar
Originally Posted by DrX
Tomāto/Tomäto
Ahh okay. I get it. Just waiting on my fittings now.
Old Mar 23, 2015 | 11:04 AM
  #44
TAPyvehc93's Avatar
Whats up guys. I need some input. So like usual, I like to do things the hard way. I'm wanting to retain the stock fuel bucket and lid with my walbro 450. I was wanting to know what you all think would be the best way to connect a fuel line to where the factory pump connected to. Now remèmber the factory pump is held into this fitting with a bracket so the pump can't come loose from the fitting. I was wondering if just a fuel line hose clamp would be enough to hold a fuel line onto the fitting without poping off from the fuel pressure. This fitting has no barbs on it. And go figure, the expensive as submersible fuel line I bought is to big for this fitting to make a tight seal. So any ideals would be great. The fitting is where the flat head screw driver is pointing at in the picture below.
Old Mar 26, 2015 | 06:01 PM
  #45
TAPyvehc93's Avatar
Hey all, I just wanted to let you know that I finally got my walbro 450 installed today. I started it up and let here run for about 5 minutes and then revved it a few times and everything seems fine. I will take it for a spin tonight. I ended up installing it the way I wanted to. I was able to retain all the factory stuff such as the fuel filter and fuel pressure regulator. I have it installed in the bucket with the sock at the bottom and the bucket lid snapped on. Will ad pictures later
Old Mar 26, 2015 | 10:03 PM
  #46
TAPyvehc93's Avatar
Drove the truck to the gym and back. Still no issues or check engine lights. Put the truck under full boost for a quick second and I didn't notice any issues. So far so good!
Attached Thumbnails Walbro 450 Install (in progress)-img_2004.jpg   Walbro 450 Install (in progress)-img_2001.jpg
Old Mar 28, 2015 | 10:15 AM
  #47
DrX's Avatar
DrX
Did you do anything with the plastic nipple to keep the hose from sliding off? Did you flare the ends of the metal tubing?
Old Mar 28, 2015 | 01:38 PM
  #48
TAPyvehc93's Avatar
The metal tubing is actually stainless steel 180* barbed fittings for soda machines haha. For the plastic nipple, it just heated it up a little bit and pressed a punch into it to add a little flare to it, and put the clamp on really tight. I tugged on the hose and couldn't pull it off the nipple, so I think it will be fine. That was really the only thing I was worried about. I also did some cutting on the lid to make room for the lines to come out and go back into the bucket.
Old Mar 28, 2015 | 10:03 PM
  #49
Byrdman11's Avatar
Glad the install went good for you. I love the 450s
Old Mar 29, 2015 | 11:06 AM
  #50
TAPyvehc93's Avatar
Ya man, so far so good. Thanks for answering all my stupid questions haha. Now I just need to wire in my ethanol sensor, then I'm going e85 and more boost!
