Walbro 450 Install (in progress)
Old Mar 29, 2015 | 05:54 PM
  #51
GXPJAY's Avatar
That's awesome, I had tried to put the 450 in a non-flex fuel bucket and it wouldn't work since the venturi/pump fill is different with that one but I do have a Flex Fuel pump in there now and my 450 still so I think I'll do it the same way you did. I assume there was not enough room to just run 1 long fuel hose up then back down? Likely too tight of a bend, just thinking that would save several clamps.
What size fuel line and 180deg hose barbs did you get?
Old Mar 29, 2015 | 06:34 PM
  #52
DrX's Avatar
DrX
What about the teflon flex hose? APE has a few lengths up 14.8". ID is 5/16"
Old Mar 29, 2015 | 10:06 PM
  #53
TAPyvehc93's Avatar
Yes, I was worried about the fuel line getting pinched by using one long hose. Thats why I used the stainless barbed fittings.
Old Mar 29, 2015 | 10:10 PM
  #54
TAPyvehc93's Avatar
What about it lol? The plastic nipple on the fuel bucket lid isn't exactly 5/16. I bought some 5/16 submersible fuel line but it was too big for the nipple. Thats why I ended up using the fuel line that came with the walbro(Not the best idea, but it will work for now, until it rots haha). Its just fit more snug. The rest of the fuel line is 3/8(I believe?) submersible Gates brand fuel line.
Old Apr 1, 2015 | 04:10 PM
  #55
GXPJAY's Avatar
Did you order those 180 deg fittings online? I can't seem to find some so if you did pls provide the link.
Old Apr 3, 2015 | 04:25 PM
  #56
TAPyvehc93's Avatar
Buyfittingsonline.com Fittings, Stainless Steel Fittings, Tube Fittings, Valves - U-Bends BAMM!
Old Feb 14, 2016 | 01:19 PM
  #57
gravedigger472's Avatar
Default How has it worked out over the last year?
Drove the truck to the gym and back. Still no issues or check engine lights. Put the truck under full boost for a quick second and I didn't notice any issues. So far so good!
@TAPyvehc93 How about a long term update? has the 450 worked out well the way you hooked it up with the U bends and stock filter/venturi/regulator thing? These last pics should be a sticky, there are a ton of people asking about getting the 450 in a PWM returnless application on here. They way you did it really looks clean.
Old May 2, 2016 | 12:45 PM
  #58
jtphelps289's Avatar
Second this^^^
Old May 26, 2016 | 09:23 PM
  #59
TAPyvehc93's Avatar
Originally Posted by jtphelps289
Second this^^^
The truck seem to run fine while I had that setup but I no longer run that setup anymore though. I still run the walbro 450 but the fuel system was later converted to a return style system. I didn't really like having two u-bends in the tank and the way I had the hose connected to the the bottom of the fuel bucket hat was a little sketchy in my own opinion, but it did work.
Old Nov 7, 2016 | 09:15 AM
  #60
Choda's Avatar
Bump. Im about to install the 450 into my 2009. It seems like the pump is a great upgrade and works but there are some installation differences between those who have done it.
I like the idea of keeping the basket as stock as possible with all the functions built into it.
