Vortec350ss 2005 Sierra Denali - Forged 370 and cog driven TVS2300
Old Mar 29, 2016 | 11:26 AM
  #751
GM1697's Avatar
You don't seem too confident...
"appears better"
Maybe it'll stall like mine
Old Apr 4, 2016 | 09:41 AM
  #752
Vortec350ss's Avatar
I got the truck idling a ton better. The throttle body is working great. I know I will probably catch some heat for this but next on the tuning front is to adjust idle to get a tad more lope out of it. Its a decent size cam for a blower, and I want it to be heard. Currently timing is at 25* as thats where I saw the best vacuum. I was thinking of dropping it to 22* or so to start. Any other pointers for slightly more chop that anyone can share?
I also decided to sack up and pulley down... this is where I will likely end up anyway.
3.2" pulley and I still have great belt wrap. With my other 100mm idler its even better...
Old Apr 4, 2016 | 09:46 AM
  #753
Smokymance's Avatar
Did you weld your water pump pulley?
Old Apr 4, 2016 | 10:01 AM
  #754
Si Senior.
It's hard to tell in the pics but I welded it and painted the hub to keep it clean.
Old Apr 4, 2016 | 10:09 AM
  #755
Atomic's Avatar
I have a gauge for that
Is the belt touching your inlet adapter piece?
Lower rpm and less timing will make it chop more, also run it a bit leaner.
  #756
Its close but no it isn't. The belt runs behind where it flares out. Tight fit though...
Old Apr 4, 2016 | 11:55 AM
  #757
camarokid6771's Avatar
where did you get that blower pulley from? it looks like a stainless magnacharger brand pulley?
Old Apr 4, 2016 | 01:11 PM
  #758
It came with my blower... but SCOL has had them in the past. I guess magnuson has been out of stock for a little while now.
Old Apr 4, 2016 | 02:34 PM
  #759
03sierraslt's Avatar
Play with you overspeed and under speed tables.
Old Apr 5, 2016 | 10:22 AM
  #760
Should I leave the overspeed stock?
