TXsilverado 2.0 Build Thread
Old Nov 11, 2012 | 10:59 PM
  #261
Vince B's Avatar
Just so you know what your looking at here.....Smart-Tech™ Input Housing Kit pictured below. Sonnax - Aftermarket replacement transmission, torque converter, and high performance automotive parts Will be upgraded with one of my billet over run pistons and sleeve kits instead of using the one supplied from sonnax. This will allow us to use a steel bonded forward piston instead of a factory aluminum 700R4 piston that is known for cracking.
Billet apply and pressure plates for the 3-4 clutch. This clutch pack will have 9 4L65E .062 frictions with 8 .077 kolene steels.
Picture of the inside of the new sonnax drum. Here is some more info on the drum. http://www.sonnax.com/system/announcement/77733-06K.pdf
Trans brake kit from Rossler. Includes springs for the reverse input drum, brake solenoid manifold body, billet reverse input spring retainer, new aluminum oil pan with bolts and modified low reverse steels.
Billet reverse input drum spring retainer.
Billet pump rotor.
New deep aluminum oil pan that will allow clearance for the brake and will also be tapped for a pass threw connector for the brakes power supply.
Old Nov 11, 2012 | 11:03 PM
  #262
BlackGMC's Avatar
Resident Retard
Looking good vince! I think i understood 3 maybe 4 words in your entire post.
Old Nov 14, 2012 | 09:41 PM
  #263
bigboy576103's Avatar
Lookin good man maybe when i have next time im down here i can swing by check it out maybe give u a hand if needed..
Old Nov 15, 2012 | 12:08 AM
  #264
TXsilverado's Avatar
come on with it. it's at a stoppping point right now until i get some more parts in....ive got some small things to do but nothing major at all. my manton 7.800 pushrods made it in today and the flex plate and ARP flex plat bolts that corey donated are here. but those are both 1 man jobs. an extra hand with the transmission would be sweet!
Old Nov 15, 2012 | 01:20 AM
  #265
AKlowriderZ71's Avatar
11 Second Hall Moniter
It's looking good Stew! I'm eager to see all these new 60E parts in action, tearing up the strip.
Old Dec 4, 2012 | 10:37 AM
  #266
had a 4 day weekend and didnt get much done . got the water pump painted up and installed. The alternator bracket that i have was modified to fit the fast 90mm intake but a buddy here on the forum is willing to trade a stocker for my modified bracket so i held off on painting and getting it on. also, my cheap *** pulley puller broke when i tried to get the pully off of the power steering pump. one day ill get some pulley pullers from somewhere besides harbor freight.
I decided to have the long side of my 8.8 cut down so went out to the pickin yard over the weekend and scored a right side axle from a 96 explorer. need a trac-loc rebuild kit and new spring perches before dropping it off at the shop that will cut it down for me.
vince sent this to me this morning.
Old Dec 7, 2012 | 09:35 PM
  #267
BlackGMC's Avatar
Resident Retard
Nice!! Hey did you get the bracket modified? I did it a different way when i had the ls6 intake. Basically it is a pulley from a vette that you mount to one of the holes in the bracket with a lomger bolt and some washers behind it. You can have it if you need it.
Old Dec 7, 2012 | 10:55 PM
  #268
i used the same method when using the ls6 and fast 92mm intake but used a much shorter belt routing. if i have the room, id rather just run an OEM belt routing. traded my modified alt bracket for a stocker today. i will cut off the portion where the power steering pump.
got my leaf spring sliders tonight. just waiting on my clutch kit and spring perches before sending out the rear end to be narrowed. i should have my Vince B LVL69 transmission in by the end of the weekend along with the flex plate and bolts that you donated. i'll prolly pull the OEM fuel system this weekend too.
Old Dec 10, 2012 | 09:07 AM
  #269
Bracket modified.
if any of you have a line on a s10 manual steering box i'd be interested.
Old Dec 16, 2012 | 09:02 PM
  #270
having a celebration beer now. some things make it feel like you're actually accomplishing something. got the trans crossmember completely bolted in today and finally dropped the cab back down to the frame. all of the a/c **** wouldnt fit with these headers. i removed it for now and will get a sheet of aluminum cut to clean up the fire wall. i still plan to run A/C and heat on this truck...it will just have to be something besides the OEM stuff. we put a vintage air system on my dads 32 coupe and it will freeze you out! and is VERY clean under the hood too. i may end up going that route. anyways
