TXsilverado 2.0 Build Thread
Old May 29, 2012 | 11:01 AM
  #91
TXsilverado's Avatar
Originally Posted by BlackGMC
interesting, i wonder what all you can control with that unit.
from what i understand, you can control all of the same things that HP controls. line pressure, shift rpm, shift drop back, and converter lock up for each gear. i'm not sure if it's capible of locking at WOT yet.
Originally Posted by Tombstone
I think someone makes a kit where a cable comes out off the carb like a kick down cable to another bracket that the tps mounts on. I found one that may work for you I will send the link to you in a pm.
rock on
Old May 29, 2012 | 11:46 AM
  #92
BlackGMC's Avatar
Resident Retard
Depending on which converter you go with you could lock it up in 2nd. Supposedly that is what alot of syclone/typhoon guys do
Old May 29, 2012 | 11:56 AM
  #93
brandon6.0's Avatar
Summit or Jegs sales the TPS kit for a carb. Seen it in one of there magazines the other day.
Old May 29, 2012 | 12:28 PM
  #94
is it ok to lock in 2nd and shift to 3rd while locked? the final decision will be based on track times. with the silverado i never saw a difference in track times by locking it....it felt better locked and i had that expensive tripple disk converter so i locked it. the track said that it ran the same though. i probably wont get the tripple disk for this build.
Old May 29, 2012 | 12:38 PM
  #95
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Do not shift while the coverter is locked, you can break the input shaft.
Old May 29, 2012 | 12:40 PM
  #96
Old May 29, 2012 | 01:09 PM
  #97
Tombstone's Avatar
I don't know if the one I sent you the link to. Will work for what you need but at least it could give you a idea on how to set one up.
Old May 29, 2012 | 01:48 PM
  #98
i think that that setup is to run with their TCU. i think the FAST TCU requres a factory style TPS.
the seller sold me a TPS with the harness and he was running a carb also...wouldnt it be badass if all of the hardware was included to attach it to my carb. fingers crossed
Old May 29, 2012 | 02:26 PM
  #99
Tombstone's Avatar
That would be nice if all the hardware need to attachet was included.
Old May 29, 2012 | 02:53 PM
  #100
i just got a text back from the seller. it has all of the needed hardware to make it work from what i understand it has a cable that connects to the carp and acts just like a kickdown cable (whatever the hell that is lol) this carb stuff is all new to me!
