Twin build
Old Nov 19, 2012 | 05:28 PM
yzriders182's Avatar
Default Twin build
So I have been trolling around a lot and reading and got the bug for boost when I bought a 02 WRX. I was in the middle of taring my truck down at the time any way, so it was on the blocks to be my new project.
I have been at it for a few months its been a slow process because I am part hunting and busy with work, but I figured I would throw up a thread because its cold and wet out=no motivation to work on it lol.
Plans
Engine
Stock 5.3l block
cam
push rods
ls9 head gaskets
head studs
valve springs
high volume oil pump
double roller timing chain
Fuel
surge tank up top
two walbro 255 pumps
60lbs bosh injectors
fuel rails
Exhaust
custom headers
50mm tail waistgates
Garrett 57mm T3 turbos
aem wide band
On to the pics.
Started out as a just lets clean up this abused pig.
Together
bed off. Some of that is rust but not a lot. most of it is the old under coat from Zebart. It never dried up and stayed tacky for ever. I live down a dirt road and it stuck like a magnet. Stuff will not wash off and is the reason I started this whole thing. I will NEVER do that again to any car. Worst stuff ever!!
Cab ready to come off
Cab off
Cleaning the frame. Used paint stripper from Home Depot and the power washer. Sprayed it on let it sit then washed it off. This is before I started stripping it down.
Painted it with por15 next. DONT GET IT ON YOUR SKIN!!! It will not come off. This is with one coat of POR on it. I did two more coats and then two top coats. It smoothed out the rough spots a lot.
On to the motor
Fuel surge tank
Cabs time to get por15
Cab going back on
Turbo
Ok this is where I am now. I have the passanger side turbo, but have to figure out what to do with the wiring harnes running over teh hot side. I was thinking of wraping it in something to protect form the heat. What should i wrap it in?
Also should i run turbo blankets? pros cons?
I am thinking of building a bracket to hold the wires up out of the way but have to get the brake booster back on and mastercylinder.
I need to still install the other turbo wire in fuel injector connectors and plumb everything. Fuel, vacuum lines, oil lines and hook up a bunch of wires.
Ill try to keep this up to date as possible. Any input is welcome. Its been a slow long process and am pumped to get this done!
Also if this is in the wrong section just let me know.
Old Nov 19, 2012 | 05:58 PM
03sierraslt's Avatar
Lots of good pictures and a fairly in depth build, Ill put it in the projects section for you.
Old Nov 19, 2012 | 06:28 PM
Thanks
Old Nov 23, 2012 | 01:51 PM
how are you guys running inter-cooler piping on these? Also how are you tying the waist gates into the exhaust? (connecting the dp to the waist gate?)
Old Nov 23, 2012 | 02:56 PM
Wilde Racing's Avatar
How do I change this text
Wow, A LOT of work....
Old Nov 25, 2012 | 10:26 AM
Got half of my injector connectors wired in and cleaned up a bit.
Played with the intercooler piping next. Got it all routed and close to where it needs to be just need to get some different boots to hook up to the turbos and clean all the dust off! lol stuff has been sitting for a bit.
Just need to trim the head light mounts put them back in and should be good.
Any ideas on how to hook up the wastegate to the dp. this is what i have. I am running different turbos that's why it isn't lining up like originally planed.
Old Nov 25, 2012 | 10:37 AM
TIM Z's Avatar
11 sec. Truck Mod
Awesome build keep em coming !!
Old Nov 25, 2012 | 01:23 PM
Thanks. Ill keep it as up to date as possible.
Old Nov 25, 2012 | 01:36 PM
Atomic's Avatar
I have a gauge for that
Might have to redo that wastegate section and incoporate a bend in there to make sure they line up...
Old Dec 16, 2012 | 04:06 PM
Got some work done the past few weeks. Just little stuff tho.
Got the Y pipe hooked up to the down pipes
Got both turbos mounted up and both waste gates hooked up too. Just needed to clock the on and motivate it with a pry bar and lined up perfect.
Got the intake on and figured out a good spot for the MAF to go. Its a tight fit but should work ok.
I also have the other side of injectors wired in and coils on with the spark plug wires routed are hooked up away from all the heat. I now have both turbos back off and the down pipes off so i can warp them in exhaust wrap.
