Turbo ccsb- TMS iron 5.7 build
Old Oct 14, 2014 | 10:52 AM
LS1TRUCKGUY's Avatar
Default Turbo ccsb- TMS iron 5.7 build
long story short, the junkyard 5.3 in my truck lost oil pressure. after no luck finding another reasonably priced junyard engine, I called thompson motorsports and ordered one of their iron 5.7s with forged pistons and rods.
Goals for this build... its just a reliable daily driver. something to have fun with. and i use it to pull a lowboy trailer with camping gear, dirtbikes, and quads. I would be happy if the truck makes 500+ on straight pump 93. eventually it will get meth and a bigger turbo. 600+ would be plain bad ***.
Specs:
5.3 block
3.908 diamomd pistons -10cc
tms rings
4340 scat i beam rods
stock crank
pac 1218 valve springs with .015 shims
BTR pushrods
LS7 lifters
212/218 563/563 113+2 cam from BTR
10:1 compression with my current 862 heads
trick stage stage 2 turbo kit with magnum t70 .70ar
I would like to give a huge thanks in advance to Kasey(06tx4.8) for helping me out with the swap since im in the middle of buying a new house and my garage is all packed up, and to wheatley for tuning this thing when its up and running
Old Oct 15, 2014 | 06:13 PM
Update: the engine is ready, so i will be picking it up friday. Should be up and running sunday or monday. I will try to get kasey to send me as many pics as he can and i will post them as i get them
Old Oct 15, 2014 | 08:09 PM
03chevytruck's Avatar
Tuned in for results! Sounds like a fun DD.
Old Oct 15, 2014 | 08:10 PM
How much boost are you planning to run?
Old Oct 16, 2014 | 07:16 AM
I need to get get a new boost controller. Mine **** the bed, so im running on the wastegate spring. Makes 10-11 psi on the wastegate spring now. Im not sure how much boost it will make with the added displacement. I would like to see 500 to the wheels on straight 93, so however much boost it takes to get there.
Old Oct 16, 2014 | 03:29 PM
That's my goal. 500 for normal driving and 600 for playing. I'll be giving it 93 and 100% meth injection. Hoping to get close to the 600 mark at 15 psi but we will see. Not really worried about the numbers to much it's just a goal that I would like to meet.
Old Oct 18, 2014 | 11:29 PM
no problem bud. motor will be dropped in first thing in the morning. new motor is all put together ready to go!!
Old Oct 19, 2014 | 06:34 AM
Old Oct 19, 2014 | 09:21 AM
Same motor as Foose04 is running, should be a strong piece!
Old Oct 19, 2014 | 12:27 PM
Yessir! I hope it is!
