Turbo.
Old Aug 31, 2010 | 01:59 AM
  #51
Daryn's Avatar
Formerly darynC-10/23/10
good job man!! i am building mine at a buddys shop... having a tubing notcher to cut them angles in the enblows is SO MUCH EASIER!!!!!!!!
what pump you went with?? 255 i assume?
Old Aug 31, 2010 | 03:38 AM
  #52
2005 Silverado's Avatar
SPAM HUNTER
Thats the one easy install if you ask me.
Old Aug 31, 2010 | 09:36 PM
  #53
SPAM HUNTER
Fuel pump is junk. Ran for 30 seconds so i could prime the system...and quit.
Kinda just ruined my mood to work on the truck right now.
Old Aug 31, 2010 | 10:04 PM
  #54
Daryn's Avatar
where did you get the fuel pump??
Old Aug 31, 2010 | 10:29 PM
  #55
SPAM HUNTER
new from texas speed.
Old Aug 31, 2010 | 10:42 PM
  #56
fortplainman's Avatar
got a sick build going man, gona tear up the track with it.
Old Sep 1, 2010 | 10:39 PM
  #57
SPAM HUNTER
Figured out the fuel pump issue today.
Got all wiring done, and the harness hooked back up.
Tomorrow i will run the feed line, and remove the pan to tap it for the drain.
Ill post up a engine bay picture tomorrow. Most of you will complain about the hoses being ran up on the fire wall instead of being hidden but i got this kit done to be practical and i didn't have to cut or change any wiring even my LC1 was plenty long to be connected to the down pipe.
Old Sep 2, 2010 | 06:49 AM
  #58
Spoolin's Avatar
GFYS and STFU
Let's see it the damage goldy locks!! I wanna see the rats nest!. Curious to see if it's as bad as Thunder's used to be!!
Old Sep 2, 2010 | 08:00 AM
  #59
SPAM HUNTER
I have seen your work as well...
All i did was run the maf pig tail across to the new location, added some injector pigtails, and vacuum lines. Then ran the wideband accross the top of the intake. An engine cover would cover is all up.
Old Sep 2, 2010 | 08:01 AM
  #60
SPAM HUNTER
Ill try for a better picture today
