TBI 350 swap in 88 Blazer, charging issues
Old Sep 7, 2011 | 10:07 PM
ZONES89RS's Avatar
In-Zane Moderator
Default TBI 350 swap in 88 Blazer, charging issues
Well, i checked the stock alternator, it is a 90 model setup, 1 wire alternator. But it was dead, swapped to a new autozone piece, it went bad, warrantied it and it was 11.4 volts, started it and went to 13.8-14.0 like it should, 5 miles drive later, i checked it and the damn thing was down to 13.0-12.8, so i assume the regulator inside got burned up.
How much voltage is required on the keyd source to activate the charging system? I thought it was 12 V, so what needs to be done?
Old Sep 8, 2011 | 05:47 AM
iamkeniff's Avatar
how old is your battery? also make sure the wire leading to the battery isnt broken/burnt.
Old Sep 8, 2011 | 12:21 PM
ZONES89RS's Avatar
In-Zane Moderator
Battery is the second good one we have installed and the small cable was replaced.
XL7
May 5, 2022 01:48 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
06 4.8
Jul 15, 2015 07:17 PM
davis28905
Jul 8, 2015 03:20 AM
