Steve-o-08's Silverado Build Thread, Take Three.
Old May 9, 2016 | 01:20 AM
  #161
X_Racing1's Avatar
how much did the new springs lower the front end? Do you run solid end links on the sway
bar?
Old May 9, 2016 | 08:34 AM
  #162
Steve-O-08's Avatar
bar?
Not sure how much lower it is yet. Just ordered my link parts last night. They should be here in the next day or two. Found some spherical ends like the posi-links Ridetech sells, but much cheaper. Going to do them on both ends to eliminate any binding. They will be solid but will allow for some more rotation.
Old May 9, 2016 | 10:01 AM
  #163
Badasschevillac's Avatar
Those wheels are awesome! makes me wish I got 18s instead of 20s. Look like volk te37s (or the rota te37 knock offs I was thinking of getting) What's the weight on them?
Old May 9, 2016 | 07:56 PM
  #164
Steve-O-08's Avatar
Thanks man. Yeah that's why I like them. I believe they are 26-28lbs each.
Old May 30, 2016 | 07:27 AM
  #165
echoman's Avatar
Originally Posted by Steve-O-08
Yes they are Level 8 MK6's. They are 18x9 with a 12mm offset. Might have them widened. I am waiting until the tires come in and see how they look. Having the wheels Cerakoted now. Might have them ready and on the truck next weekend. Depends on how busy the coaters are. Will be running a 315 series tire all the way around.
Just seen your reply lol! Thanks for the info man! I'm really leaning toward getting a set of these to save weight over my chrome 20" torque thrusts without paying an arm and a leg.
Old May 30, 2016 | 05:08 PM
  #166
Three6GMC's Avatar
Very cool project something different for sure. Here where I live autocross isn't really big so never been really exposed to it but looks like a lot of fun.
Old Jun 19, 2016 | 03:02 PM
  #167
thebwlife's Avatar
What DJM LCAs are you running 3" or 4"? w/ a 6" rear flip right?
Also on her truck is she still at 3/6? 3" springs right?
Of the two options would you do LCAs or setup like hers? Or maybe even do spindles and a 1" spring? Any alignment issues on either. I'm in the process of trying to do a "pro-touring" style truck also.
Old Jun 19, 2016 | 04:43 PM
  #168
Mconcha's Avatar
If you went with a 275/45/18 on all four corners (let's say Bridgestone RE71 or toyo R888's) on your 18x9's you would have minimal sidewall roll in the corners and probably have faster lap times compared to 315's. A 18x11 or 18x12 would make sense for a 315 for autoX. I ran a 305/30/19 Michelin pilot SS on 19x10.5's on all 4 corners with good results.
If I'm not mistaken the pchrods c10 runs a 18x12 wheel with 315/30/18 Falken on all 4's. Or at least it did the last time I saw it.
Attached Thumbnails Steve-o-08's Silverado Build Thread, Take Three.-image.jpeg
Old Jun 25, 2016 | 12:36 AM
  #169
Steve-O-08's Avatar
Thanks! It really is a lot of fun.
I am running a 3" drop arm. No alignment issues. The benefit of the arms is less weight, either combo would be pretty effective.
Ran the truck last weekend and they worked well. Ideally I'd like to have the wheels widened to 10 or 10.5. Just to eliminate the sidewall flex. Running a few pounds higher pressure was working just fine. Rob's truck has 335's on 18x12's. Going through pictures from last weekend. I'll get some pictures up here soon.
Old Jun 25, 2016 | 03:34 PM
  #170
Mconcha's Avatar
335's are crazy, but so is the rest of his truck so I trust his judgment. How do you like the long first gear of the 4l80 for auto cross? My theory was it seems appealing b/c you could just leave it in 1st and rev the heck outta it. Any feed back you could give on that theory?
