Steve-o-08's Silverado Build Thread, Take Three.
#162
Not sure how much lower it is yet. Just ordered my link parts last night. They should be here in the next day or two. Found some spherical ends like the posi-links Ridetech sells, but much cheaper. Going to do them on both ends to eliminate any binding. They will be solid but will allow for some more rotation.
#165
Yes they are Level 8 MK6's. They are 18x9 with a 12mm offset. Might have them widened. I am waiting until the tires come in and see how they look. Having the wheels Cerakoted now. Might have them ready and on the truck next weekend. Depends on how busy the coaters are. Will be running a 315 series tire all the way around.
#167
What DJM LCAs are you running 3" or 4"? w/ a 6" rear flip right?
Also on her truck is she still at 3/6? 3" springs right?
Of the two options would you do LCAs or setup like hers? Or maybe even do spindles and a 1" spring? Any alignment issues on either. I'm in the process of trying to do a "pro-touring" style truck also.
#168
If you went with a 275/45/18 on all four corners (let's say Bridgestone RE71 or toyo R888's) on your 18x9's you would have minimal sidewall roll in the corners and probably have faster lap times compared to 315's. A 18x11 or 18x12 would make sense for a 315 for autoX. I ran a 305/30/19 Michelin pilot SS on 19x10.5's on all 4 corners with good results.
If I'm not mistaken the pchrods c10 runs a 18x12 wheel with 315/30/18 Falken on all 4's. Or at least it did the last time I saw it.
#169
#170
335's are crazy, but so is the rest of his truck so I trust his judgment. How do you like the long first gear of the 4l80 for auto cross? My theory was it seems appealing b/c you could just leave it in 1st and rev the heck outta it. Any feed back you could give on that theory?
