Slow and getting slower
Old Apr 1, 2012 | 02:52 AM
  #741
TTownTech's Avatar
Do VTD relearn on the key.
Old Apr 1, 2012 | 02:54 AM
  #742
TTownTech's Avatar
Try to crank the truck let the key back to run, 10 min the security light should go off, cut the key off and do it to more times. If the theft deterrent is the problem that'll take care of it
Old Apr 1, 2012 | 08:32 AM
  #743
Atomic's Avatar
I have a gauge for that
Even with vats disabled this is needed? Very annoying
Old Apr 1, 2012 | 09:08 AM
  #744
TTownTech's Avatar
That one I don't know about. I just started playing with hptuners a couple months ago. I just know you've got to do a theft deterrent relearn on a stock PCM. Maybe someone else knows more.
What missing? Fuel or spark?
Old Apr 1, 2012 | 11:20 AM
  #745
vanillagorilla's Avatar
Originally Posted by Atomic
I got the downpipe problem fixed but the coolant res is all in my business....
Use a C5 coolant res and tuck it up by the fender/firewall brace. They're about $50 on epay. It works pretty well and you just have to tap into the heater hose line. I went through the same thing, and nothing I did with the stock res looked right.
Old Apr 1, 2012 | 12:03 PM
  #746
Atomic's Avatar
Got any pics?
Im in the process of doing the security relearn, but even after 30 minutes the security and battery lights dont stop flashing.
Old Apr 1, 2012 | 02:52 PM
  #747
TTownTech's Avatar
Re-enable the VATS. Might be the fact you disabled it fighting with itself. Tried to tell mine it had no Nuetral safety so I could crank it w/o the trans hooked but it still wouldn't cooperate.
Old Apr 1, 2012 | 03:02 PM
  #748
TTownTech's Avatar
Mine still has vats but I like extra security knowing that everyone can hear it pull up, and the right theif could convince himself that I actually have a real engine under the hood lol
Old Apr 4, 2012 | 12:33 AM
  #749
Atomic's Avatar
Got it fixed. I had the maf codes set to no error report instead of just no mil light. Something so simple and ive been pulling my hair out for days. Changed that little thing and it started up fine and purred like a kitten.
Heres a little teaser vid, with 40% throttle, up a hill, in 3rd gear, torque converter unlocked, with about 6lbs of boost
http://youtu.be/CwQQJJ7rDO4
Old Apr 4, 2012 | 12:36 AM
  #750
smokeshow's Avatar
Mod with training wheels
I'll let you try again. 100% throttle this time.
