Slow and getting slower
Old Mar 20, 2012 | 10:40 PM
  #691
Bumpers's Avatar
Yes I gave useful information
Old Mar 21, 2012 | 08:21 PM
  #692
Atomic's Avatar
I have a gauge for that
Got the chance to put in my new front driveshaft from DSS. My 4th shaft from them, excellent guys. Fits perfect and clears the turbo crossover, oil feed, and transmission, albeit very closely. I had cut off my old yokes and sent them in and had them replace the ujoints with solid spicers and upgrade the shaft to their thicker steel, its still 2.75" od.
Also took the chance to measure the tires to make sure they are the same size since 4wd will not work if they arent...I measured the circumference to be less than 1/8" difference front to back, so I should be golden.
Now im working on installing the plugs and double checking some wiring.
Old Mar 22, 2012 | 09:18 AM
  #693
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
you plan on bringing this to the next meet (if we ever decide on a date) in Jackson?
Old Mar 22, 2012 | 10:11 AM
  #694
Atomic's Avatar
Yea if I can get all of the kinks worked out
Old Mar 23, 2012 | 03:48 PM
  #695
Atomic's Avatar
Well I almost ******* died in a painful death a few minutes ago, lets just say raw fuel dumping onto turbo hot pipes is a big no no. More info in a minute. Truck is fine.
Old Mar 23, 2012 | 03:50 PM
  #696
badz24s's Avatar
video of said incident?
Old Mar 23, 2012 | 04:19 PM
  #697
smokeshow's Avatar
Mod with training wheels
Richard, I think you're a bit of a pyro.
Old Mar 23, 2012 | 04:21 PM
  #698
badz24s's Avatar
he is a rocket scientist, you know.
Old Mar 23, 2012 | 07:37 PM
  #699
chevyboy.520's Avatar
Does it go faster with the fuel on top of the turbo and hot side? Rather then being forced threw it? Your definatly trying new stuff on this one!
Old Mar 23, 2012 | 09:17 PM
  #700
Atomic's Avatar
ha, no. The oring in the fuel rail above number 5 cylinder failed so fuel was spraying out of there for about ten minutes before I could get back home, lost probably 5-6 gallons. Its a miracle it didnt catch on fire.
