Slow and getting slower
Old Aug 22, 2011 | 08:42 PM
  #221
rjwz28's Avatar
Man Motor club
I care I've been following forever and I've never even owned a GMT800 (daily drove my dad's 03 for a while though). Sweet build.
Old Aug 24, 2011 | 05:03 PM
  #222
Atomic's Avatar
I have a gauge for that
Well class has started back so progress will be a lot slower. I didnt get near as much done in a week as I thought I would, mainly because those seats took a day each to make the brackets.
I had to redo the 10b gearing today because I didnt get the crush sleeve completely crushed and had the most horrible noise youve ever heard when coasting at 30mph+
Heres the pattern I got after today's tinkering
This brings up an interesting thought...when I was searching the interwebs to find possible solutions to my problem, I found a lot of high-hp guys using solid spacers and shims instead of the crusher washer to get the right pinion preload. Any experts have an opinion on that?
Also I discovered the trans crossmember on my 99 is different than my 04. What this means is the crossmember I had made will not work and I will have to come up with something custom
Old Aug 24, 2011 | 05:21 PM
  #223
black00chev's Avatar
Slowest turbo build ever!
The solid spacer is really easy... Just torque down a fresh crush washer and pull it back out, mic it and make a solid spacer the same size. Did this when building the Ford 9" for my dads car. Started a thousandth or two bigger then what the crusher washer was and worked out perfectly.
Old Aug 24, 2011 | 05:23 PM
  #224
Atomic's Avatar
My question is more of is there any advantage of the crush sleeve vs solid spacer or vice versa?
Old Aug 24, 2011 | 05:42 PM
  #225
smokeshow's Avatar
Mod with training wheels
Being able to reuse it instead of having to replace the sleeve every time you mess with the pinion.
Old Aug 24, 2011 | 06:14 PM
  #226
Beatdown Z's Avatar
Laid Back
All you have to do with the '99 crossmember is slide it back, drill some new holes in the frame, and bolt it up!
Old Aug 24, 2011 | 06:40 PM
  #227
That and its just stronger. Think about it, the crushed piece of metal has a chance it could compress slightly more and throw off the gear pattern. I may do this with mine when I put in my truetrac.
Old Aug 24, 2011 | 09:25 PM
  #228
smokeshow's Avatar
If you've got a careful eye and a steady hand you can get away with reusing the crush sleeve. Just make a line of marks on the pinion, nut, and yoke and then take it apart and reassemble it. Long as the marks line back up you're good. I did that like 2k miles ago, still runs great. Up to you...I just replaced a pinion seal so I didn't really feel like ripping the whole thing apart to replace the sleeve.
Old Aug 24, 2011 | 09:48 PM
  #229
Atomic's Avatar
I reused the old one and it works perfect....gotta be careful tightening it back though. I compared them when I had it apart and the old one was slightly more compressed, which satisfied my reasoning of what was wrong. I like the idea of a solid for my 14b though, just wanted some feedback first.
Old Aug 24, 2011 | 10:43 PM
  #230
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Looks like you got a pretty good pattern this time around.
