RCSB build
Old Feb 26, 2012 | 05:05 PM
  #291
AKlowriderZ71's Avatar
11 Second Hall Moniter
Hmm, well I've never had to tear down an engine that soon after building it. So I can't say if that looks normal or not. I know that those light scratches are nothing to be worried about though. I just don't know what to say about the coating.
If I was in your shoes, I'd run them and not worry about it. I'd just go through the process of measuring all of the clearances again during assembly. I wouldn't skip any steps this time.
Old Feb 26, 2012 | 05:06 PM
  #292
Do those pistons use offset pins?
Old Feb 26, 2012 | 05:08 PM
  #293
smokeshow's Avatar
Mod with training wheels
No offset pins. No steps were skipped last time, just getting bad information from 'industry professionals'...this **** is getting old. It really looks like the pistons were side loading in the bore, and if that is true I know exactly why.
Old Feb 26, 2012 | 05:13 PM
  #294
Please go on...
Old Feb 26, 2012 | 05:22 PM
  #295
smokeshow's Avatar
Cylinder bores were likely too big. I gave the machinist the pistons and the specs that came with it. Wiseco specified .0035 PTW clearance, I come to pick the block up and it was .0055. Wasn't what Wiseco specs said but he builds engines for a living, all I could do was assume he knew what he was doing. He explained why it had that clearance, making more power makes more heat, etc.
Old Feb 26, 2012 | 05:23 PM
  #296
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Looks like too much cylinder wall clearance to me.
Also make sure you measure each journal in three spots then rotate 90* and measure again. It's not uncommon for the journals to taper which can lead to the same bearing problem again.
Old Feb 26, 2012 | 05:25 PM
  #297
1slow01Z71's Avatar
Beat me to it
Piston alloy plays a part in that tolerance too, which one did you use?
Old Feb 26, 2012 | 05:29 PM
  #298
smokeshow's Avatar
I used 2618s. They grow a lot, but certainly not more than the amount of clearance Wiseco specified.
Old Feb 26, 2012 | 05:33 PM
  #299
1slow01Z71's Avatar
Must be planning on pushing it pretty hard huh?
Old Feb 26, 2012 | 05:37 PM
  #300
Atomic's Avatar
I have a gauge for that
The pistons from my 410 looked similar, but I assumed it was from the one piston melting and metal fragments going everywhere...
