Project Silver Bullet!
#154
#155
#156
with quick googling i think you are correct. let me know, if they are like the 450's i may have everything you need to run dual pumps. youll just need get PM's working so we can exchange information if you decide you want to buy my parts
#157
Will do. Only issue may be the adapters may need to be enlarged to accommodate the wider inlet on the pump. 525 is 11mm and 450 is a 10mm inlet.
#158
where do you see that the 450 is 10mm inlet? i only see 11mm. from what i can see is that the inlet and outlets are same between the 450 and 525
#159
https://walbrofuelpumps.com/walbro-4...tive.html.html
If you have the adapters that fit onto the pump and the 450 filter, I can probably just have the one where it fits on the pump machined and take 1 mm off. Then the tubing you have can be used along with a 450 filter that has the smaller diameter inlet.
#160
At the bottom of this page, description states: Outlet diameter: 10mm (3/8") Diameter (upper body) 39mm Diameter (lower body) 50mm
