Project Silver Bullet!
Old Dec 17, 2020 | 02:53 PM
  #151
maxmodder's Avatar
Originally Posted by zblee
pm me your setup and ill see what i have that would work for you
Unfortunately it won't let me PM as I am a new member.
Old Dec 17, 2020 | 02:55 PM
  #152
zblee's Avatar
well your going to want to meet the requirements so you can PM when it comes to payment and shipping. pm when you meet the requirements.
Old Dec 17, 2020 | 02:56 PM
  #153
maxmodder's Avatar
Do the vapor ports on the 525 walbro need to be submerged at all times? If so, I don't think I can stagger them and extend the filter.
Old Dec 17, 2020 | 02:59 PM
  #154
zblee's Avatar
I don’t know, I used 450’s
Old Dec 17, 2020 | 03:03 PM
  #155
maxmodder's Avatar
Well 465's and 325's you can't, but the 525 should be similar to the 450. I'll get with walbro and find out and get back to you. The 450 has a 10mm inlet while the 525's have an 11mm inlet.
Old Dec 17, 2020 | 03:09 PM
  #156
zblee's Avatar
with quick googling i think you are correct. let me know, if they are like the 450's i may have everything you need to run dual pumps. youll just need get PM's working so we can exchange information if you decide you want to buy my parts
Old Dec 17, 2020 | 03:23 PM
  #157
maxmodder's Avatar
Will do. Only issue may be the adapters may need to be enlarged to accommodate the wider inlet on the pump. 525 is 11mm and 450 is a 10mm inlet.
Old Dec 17, 2020 | 03:37 PM
  #158
zblee's Avatar
where do you see that the 450 is 10mm inlet? i only see 11mm. from what i can see is that the inlet and outlets are same between the 450 and 525
Old Dec 17, 2020 | 03:44 PM
  #159
maxmodder's Avatar
At the bottom of this page, description states: Outlet diameter: 10mm (3/8") Diameter (upper body) 39mm Diameter (lower body) 50mm
https://walbrofuelpumps.com/walbro-4...tive.html.html
If you have the adapters that fit onto the pump and the 450 filter, I can probably just have the one where it fits on the pump machined and take 1 mm off. Then the tubing you have can be used along with a 450 filter that has the smaller diameter inlet.
Old Dec 17, 2020 | 03:54 PM
  #160
zblee's Avatar
this says outlet not inlet
