Project Kermit
Old Sep 11, 2009 | 11:35 AM
  #751
Nevada79's Avatar
Originally Posted by Wilde Racing
please tell me you didnt use wire nuts?????
It's ok because it's taped up right?
Old Sep 11, 2009 | 12:01 PM
  #752
Spoolin's Avatar
GFYS and STFU
Originally Posted by 95 bright teal
Exhaust is looking Pimp!
When I wired the cutouts on my camaro i tapped into the wires under the kick panel below the steering column. I had mine powered on only when the key was in the first position or truck was running which was the pink wire.
You can run them off the accesorry circuit which is the orange, or the constant power which is red there should be two of those
http://www.bulldogsecurity.com/New%2...lsize99-02.htm
Awesome!! Thanks, I'll see what I can do!! That might actually help prevent me from burning my truck to the ground!!
Originally Posted by twolow02fransen
thats
but any who the exhaust looks real good the only thing is i would get it powder coated or ceramic coated just a thought as far as wiring the cutouts i would wire them like stated above inside the cab. why no picks of were the cutouts are dumped
oh we need video of how she sounds
Next year I'm gonna get a fuel cell and re-route some of the exhaust tips from the cut-outs on out so that the driver's side dump doesn't go under the frame but around the raised section of frame where the fuel tank is. So after I get that done I will get it coated to make it look alot nicer!!
I'll get pics of it today, trying to trouble shoot a brake issue right now.
Originally Posted by sharpshooter
The exhaust is a work of art! You might have already said this prior but what FI will you eventually run?
That rear brake that is stuck you might want to re-bleed that caliper again.I had to re-bleed mine because one caliper was sticking.
I have not mentioned anything yet, however it's gonna be something kinda different. Don't wanna talk about it till I'm sure that it will work and I do enough research.
Originally Posted by blkssncpt
WoW!!! yeah man thats not a bad price at all actually, a little over my range now but i will definately hit them when i need my exhaust redone again. hhhmmm makes me wanna get a turbo sooner...
-Rob
Lol...do it!!!
Ummm...
Say the word and I'll change it I guess. What are the disadvantages of it?
Originally Posted by lawson4450
thanks man and I want to put something there but i just havent found something to go around both of them that i like i may just take a piece of stainless i have sitting in the garage and make my own the exhaust looks **** by the way.
Sounds good man!!
Old Sep 11, 2009 | 12:41 PM
  #753
blkssncpt's Avatar
Originally Posted by Spoolin
Lol...do it!!!
lol, i have learned to be patient when it comes down to the truck. but i have a plan for next tax season and my tax return so we'll see how that plays out...
-Rob
Old Sep 11, 2009 | 04:49 PM
  #754
Spoolin's Avatar
GFYS and STFU
Well last night I drove the truck about a mile to see what other possible items might pop up, so far other than the brakes and the tune all seems good. Had a bad smell of brake dust because of that left front one being so damn tight and the rotor got hot but other than that she feels good. Seems to have quite a bit of get go for only going maybe %30 TPS. Shifted smooth and confortably, has good power from what I could tell and with the cut-outs closed it sounds pretty good but quiet enough to where it won't be noticed...curious to hear what it sounds like at WOT though.
Took a few pictures this morning, so here ya'll go. Let's hear it good and bad!
Like I've mentioned previously, gonna get a flat black powder-coated plate to go around the hole, not sure if it's gonna be solid or riveted and what exact shape it's gonna be, rectangle or cylindrical or what but the main criteria is for it to be subtle in appearance. Also think I might get some tips, powder-coat those flat black as well just so there isn't the rough edge of a cut pipe.
Edit: I'm gonna paint the inside of the pipe as well, see if I can't get rid of that visible aluminzed steel sticking out from the inside of the pipe.
Old Sep 11, 2009 | 07:26 PM
  #755
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
looks good IMO but we need some vids
Old Sep 11, 2009 | 07:37 PM
  #756
CurtD's Avatar
10 Second Truck Club
They did a good job on the exhaust...like to here it open and closed at wot when you get your brake problem fixed. I even like the side exit..get you some rustoleom flat black bar-b-que paint it will cover the pipe good and it has rust inhibitors in it so the cut end won't rust
Old Sep 11, 2009 | 07:43 PM
  #757
Spoolin's Avatar
GFYS and STFU
Lol...I need to wire up the cut-outs first to do that!
You and me both Curt!! I'll see what I can do but it probably won't be for a week if not more until I can get my brake issue figured out and spend a little more time on my tune. But once I do I will take some vids of each and post them up! I'm my way out right now to get some rustoleom flat black bar-b-que paint and see if I can't black them out a little better, thanks for the tip!!
Old Sep 11, 2009 | 07:48 PM
  #758
JakeBrakeIH's Avatar
the side exhaust came out better than I thought it would...shes defiantly comin together!
Old Sep 11, 2009 | 08:08 PM
  #759
ChevyTruck's Avatar
something else
What are you doing online get out side and finish that damn thing so we can hear what it sounds like.
Old Sep 11, 2009 | 08:38 PM
  #760
1FastBrick's Avatar
Custm2500's Rude Friend
Get that bucket of bolts fixed yet??? Come drop off my parts... Hurry up...
