Project Kermit
Old Aug 27, 2009 | 02:36 AM
  #651
Spoolin's Avatar
GFYS and STFU
Originally Posted by twolow02fransen
I want to see some dyno numbers on that intake hurry up would ya
Don't get your hopes up, you realize what this engine is and what it was built for right!?! I've made about 9xx hp at the crank with this motor before but the compression is somewhere around 8.8:1. Until I throw boost at this motor it's not gonna be doing anything special!
I'm guessing mid 3xx's at the wheels until I start throwing some boost on it, then it'll be a different story.
Old Aug 27, 2009 | 03:20 AM
  #652
00Silv4.8's Avatar
dam dude thing is sittin pretty. Start it up already!!!
Old Aug 27, 2009 | 07:09 AM
  #653
thunderwagen's Avatar
That tube does look wrong bro. I will get you some pics of mine when I get home from work.
Old Aug 27, 2009 | 08:08 AM
  #654
BlackGMC's Avatar
Resident Retard
Looking good, but i have a couple of questions
Are you going to use the MAF, i noticed you had it hooked up. Also are you going to run open or closed loop on your tune?
Also where is your vent line from the pasenger side valve cover run? Where did you run your PCV line.
The reason i ask is because if you are going to run a MAF in closed loop and you have that vent line from the passenger side valve cover open to atmosphere then your trims will go nuts. That vent line needs to be run to a spot before the TB.
Old Aug 27, 2009 | 08:57 AM
  #655
charcold-bowtie's Avatar
i think you have a 60e tube.
Old Aug 27, 2009 | 04:01 PM
  #656
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
yeah i understand but it seems like everybody thats got this intake doesnt have any dyno numbers to prove it at least yet im just bugging to see what it will do for use truck guys verse's the fast or the ls6 intake swap i know theres a thread about this intake on here somewhere
Old Aug 27, 2009 | 04:55 PM
  #657
Spoolin's Avatar
GFYS and STFU
**** yeah!!!!!!!!!!!!!!!
Old Aug 27, 2009 | 05:26 PM
  #658
BlackGMC's Avatar
Resident Retard
I am assuming that means you started it???
Old Aug 27, 2009 | 06:20 PM
  #659
SLOXCAB's Avatar
nice are you out laying rubber
Old Aug 27, 2009 | 07:15 PM
  #660
Spoolin's Avatar
GFYS and STFU
The MAF is hooked up and I'm running closed loop for now. I have the PCV system run to those two breathers, one's coming from the LS6 valley cover and the second one is coming from a vent in the drivers side valve cover. I don't have any vents on the passenger valve covers.
So far things seem to be ok but I'm about to embark on my first real tuning endeavor. First thing I'm gonna start playing with is the gps at idle while in gear. I understand what your talking about, just kinda learning as I go as far as the trims go. Eventually I will have to address it as you state but I'm not there just yet.
I won't be able to do that for a while, need to learn how to tune my vehicle.
