Project EFI to Carb in my 2007 Silverado
Old Dec 14, 2011 | 11:33 PM
  #21
pewterliftedz's Avatar
looking good phantom.. i can't wait to see the end results with a plate.
Old Dec 16, 2011 | 10:34 PM
  #22
1989k1500's Avatar
Originally Posted by Bigschwerm
Good luck with your build. I would suggest contacting Pro Systems for the carb choice. I switched from a quick fuel and had pro systems build me a carb specific to my setup in my s10 and couldnt be happier.... Just a thought. Either way its honna be a fun build.
They are 10-15 minutes from my house and I haven't been impressed by their work. They setup a carb for my friends Chevelle and it didn't run worth a **** until he took their carb off. They did an e85 carb for another friends circle track car and the only time it ran ok was wide open.
Old Dec 16, 2011 | 10:41 PM
  #23
00ChevyScott's Avatar
Wearin' da big hat
How do you rig up the TPS sensor in this kind of build? Is there an adapter plate to put it on the other side of the carb?
Old Dec 16, 2011 | 10:47 PM
  #24
BlackGMC's Avatar
Resident Retard
He does need a tps since his tranny is a manual valvebody if that is why you were thinking he did.
Old Dec 17, 2011 | 08:17 AM
  #25
Phantom's Avatar
11 Second Club
I have a manual valve body trans so I won't need tps. But there is a company that makes an adapter to make it work if I did
Old Dec 18, 2011 | 05:17 PM
  #26
Phantom's Avatar
11 Second Club
Just thought of a possible obstacle. Since I'll be doing away with factory PCM, how will I start my truck? I had to hook my park neutral switch up before it would run when I put the new trans in
Old Dec 18, 2011 | 05:18 PM
  #27
Phantom's Avatar
11 Second Club
Basically I don't know if the pcm tells the bcm anything that will cause troubles once the pcm is gone. Thanks
Old Dec 18, 2011 | 05:20 PM
  #28
sprayedenali's Avatar
wont be any different than when people go to a BS3 system or something similar will it?
Old Dec 18, 2011 | 05:23 PM
  #29
Phantom's Avatar
11 Second Club
That's a good point. Just trying to figure it out for sure
Old Dec 19, 2011 | 10:15 AM
  #30
blackcash's Avatar
If you're going carb now and aftermarket EFI later, why not rip out all the factory wiring and go with say a Painless setup or something along those lines? To me it would seem easier.
