Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#481
transmission just about ready to come out, all wires and misc lines removed. All thats left are the flexplate bolts, bellhousing bolts, and crossmember bolts.
Any tips on holding the crank bolt or flexplate without a partner? otherwise I'm at a standstill until I can get a helping hand......
#483
How do I change this text
Originally Posted by moregrip
flexplate bolts out, break time
I reinstall one of the lower torquce converter/bellhousing cover bolts in the top hole. Then with a good sized pry bar hold the flex plate with the bar resting on the bolt and teath, It's a bit tricky the first 7 bolts, but by the time you pull the trans the fourth time you'll be a pro.
BTW, Looking good...
#484
tranny out, holy **** that really sucks some hind-tit (doing it by myself and on my back the whole damn time)
I'm freakin beat, thank god thats done
misc markings on the 80e:
cool pic! btw, is it going to be ok with my oil pan resting on that crossmember for now? got a piece of wood in there to take up most of the space....
here's a look at my TR6's with 30k on them:
that's it for today, must......get.......sleep
#487
man oh man, let's just say I'm sore EVERYWHERE!
had an incident last night, truck slipped off the floor jack...........I say again, the truck slipped off the floor jack! It really kinda surprised the **** out of me. Luckily when I work alone I follow extra safe procedures and it was a somewhat controlled 2-3" drop until it landed on a pair of jack-stands. This has NEVER happened to me before, and the more I think about it the more pissed off I get about the whole thing. Granted the truck was at a slight angle, but nothing crazy at all and certainly not worthy of what happened.
What was really weird about the whole thing was that the wax coating on the truck frame seemed to act like butter and actually lubed(read: helped) the damn cycle of events.
first pic, here you can clearly see the wax coating smeared as the floor jack slid off the steel reinforced cross-member jacking pad:
and in these pics you can see where the remaining steel reinforced cross-member jacking pads are dented in where the truck fell onto them. Frame/crossmember seems to be fine, however I see some larger 3/8" metal plate being welded in-place in the near future......
#489
Originally Posted by Wilde Racing
That is scary! It would suck to get crushed by your own truck with noone around to help out, don't sound fun at all..
