Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old May 21, 2006 | 06:50 PM
  #291
moregrip's Avatar
what a rush!
my system has uses Magnaflow HF cats that are 8" long
Old May 21, 2006 | 08:27 PM
  #292
TravisH's Avatar
Thank you, Sir!
One more, was that end to end or just case length?
Old May 21, 2006 | 09:05 PM
  #293
moregrip's Avatar
what a rush!
Originally Posted by TravisH
Thank you, Sir!
that was end to end
Old Nov 1, 2006 | 06:30 PM
  #294
Mort's Avatar
Cool
I have adjusted mine to:
Front shaft down 2* to rear.
Rear shaft down 2* to rear.
Pinion yoke face 92*. ( facing up to front)
It still feels to me like it is binding a little when I first accelerate. I have never felt any real vibration either but I cannot seem to get rid of the feeling that the u-joints are bound up a little when I accelerate from a dead stop.
Measure the pinion face and see what you get.
Old Nov 1, 2006 | 06:32 PM
  #295
moregrip's Avatar
what a rush!
I have a 2pc drive shaft and experience absolutely zero vibration, here are the drive shaft angles:
rear shaft @ differential yokes:
rear shaft @ carrier bearing yokes:
front shaft @ slip joint
front shaft @ transmission yokes
Old Nov 1, 2006 | 06:38 PM
  #296
Nice to know, but there are a few factors left on the table when doing it that way.
The main one being how level the ground is that your vehicle is setting on.
That could throw a few of us off if it is not setting at a 0* level from the beginning.
I need to check mine as well. The 2" shackles only gave me a vibration from a standing start up until 20mph. That is only under any given acceleration.
Mines probably setting close to 2* at the driveshaft going into the pinion.
It looks almost level with the driveshaft now.
Hey Moregrip, are you using shackles and hangers??? I see the Caltracs! I like.
Either way, nice write up. Just very curious on how sure you are about the truck setting on level ground.
Jim
Old Nov 1, 2006 | 06:40 PM
  #297
moregrip's Avatar
what a rush!
Jim
ground is perfectly level
Old Nov 1, 2006 | 06:42 PM
  #298
Question
Cool, thanks. Just wanted to make sure!
What about the shackles and hanger question??
Are you using any of them?
Jim
Old Nov 1, 2006 | 07:18 PM
  #299
moregrip's Avatar
what a rush!
Jim
DOh sorry
I am using the stock shackles and hangers
  #300
moregrip's Avatar
what a rush!
Pinion angle:
