Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Sep 18, 2007 | 05:50 PM
  #1851
moregrip's Avatar
what a rush!
Originally Posted by BlownChevy
makes sense. Do they list an "operating" temp range for this coolant?
max power @ 200-210 degrees
Old Sep 18, 2007 | 05:55 PM
  #1852
moregrip's Avatar
what a rush!
Oh, scratch that idea. If the temp ranger were lower it would be interesting to try it in the intercooler system. However like water wetter, the temp range is too high to be effective.
I asked them about that a while back and they said running it in the I/C was NOT the right application for it and stick with 50/50
Old Sep 18, 2007 | 10:52 PM
  #1853
moregrip's Avatar
what a rush!
got the new radiator and efans installed today, hooked up the engine oil cooler lines, low tempo type day, have duty tomorrow so no more work until thursday.
Old Sep 18, 2007 | 10:59 PM
  #1854
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Come on Devon, you know better then to post without pics we are spoiled
Old Sep 19, 2007 | 01:25 AM
  #1855
CHEVRACER83's Avatar
yeah wheres the damn pics.... you did this on purpose.... this thread should be deleted
Old Sep 19, 2007 | 07:46 AM
  #1856
Slowhawk's Avatar
LS1Tech Sponsor
We run Evans coolant on wet sleeve blocks to help with air pockets. Tried it on stock blocks and it never worked.We had to pull timing due to KR from the higher heat.
Here is the Rad we ran in our 408ci/S85mm truck. It is a early 90's truck style radiator from Jegs.2 core aluminum. It's huge and this truck would not get over 185 degree's in 100 degree heat sitting in traffic(probly be lower if we had better fans).After a 3 gear WOT pull temps would climb to the 180's at most.
Evans has it's place but I wouldn't run it in a truck setup like the one's listed.
Old Sep 19, 2007 | 10:18 AM
  #1857
04Denali's Avatar
I sure would like some more feed back on the evens system, kinda late for me since the water pump, T-stat and new radiator is already bought.
Sorry for Hi-jacking your thread Devin.
Mark
Old Sep 20, 2007 | 10:23 PM
  #1858
moregrip's Avatar
what a rush!
been thinking about a break-in schedule for the engine, as of today I think it's going to look like this:
0-100miles 30wt petroleum
100-500miles 30wt petroleum
500-2500miles 15w-40 petroleum
normal intervals after 2500 miles will be a blend of synthetic motor oil
something like 4 qts of 10w40 2 qts of 20w-50 or
5 qts of 10w40, 1 qt of 20w-50
Old Sep 20, 2007 | 10:32 PM
  #1859
kbracing96's Avatar
I think you have too much time to think about things.
Old Sep 20, 2007 | 11:01 PM
  #1860
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I wouldn't worry about the viscosity steps personally (and wouldn't mix viscosities when you blend). I'd also just buy a blended synthetic rather than blending by the quart like that. That way you know the chemistry is exactly what you want.
