Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
#1101
Originally Posted by moregrip
question:
do I need to connect this back on the tranny or can I just cap the hard line on top of it?
#1103
Originally Posted by TurboGibbs
Don't cap it. That is the tranny vent tube. If you cap it you will push fluid out your seals when it heats up.
On the crank bolt, I've done it atleast 9 times each with a new bolt and just tighten the fu@k out of it. Haven't had a problem.
#1104
on the crank bolt you just need it to hold in there. 100lbs sounds good with some blue loctite.
#1107
hey grip, I just saw the pictures of the truck, it looks awesome! How many inches are the rims and do you have a lift under it? If yes how much? Thanks man! The relationships look great!
#1108
