Project 1999 OBS GMC / whipple lq4 / FLT 4l65
#103
FLT put 4l65 internals in the housing of a 4l60 to match the wiring, shifting and mounting in my truck so it was 100% bolt in. they bolted an LS bellhousing to that body as well
#105
yes it has a code right now for an emissions valve its not seeing but the tuner can delete that. when they inspect it they will plug into the new ODBII port which is under the hood and the VIN will match and have no codes so it should pass no problem.
#106
throwing no codes now
http://www.youtube.com/watch?v=38LkLZobepE
dynod it too,
http://www.youtube.com/watch?v=18kovE6wnkY
http://www.youtube.com/watch?v=YwBcRBBHAHI
http://www.youtube.com/watch?v=ZHuV0c9HR8g
2nd gear runs unimpressive
3rd gear runs could not hit max rpm because of **** tires but hits 500 ft lbs at 3k
4psi as of now, gotta pulley it down etc
dynod it too,
#108
Thanks, thats the type of axle I used in my offroad truck. I even swapped dana 44 front disc calipers and 12" rotors onto it.
![](http://tharf.com/albums/classics/P1010016.jpg)
I already bought the truetrac, I'm going to stick to the 8.5" rear for now.
GrooveCityZ71
08-31-2015 12:05 PM
primal1
08-22-2015 07:03 PM
