potato land build, 9's@140+ is the goal
Old 10-31-2014, 07:01 AM
  #281
I have a gauge for that
Atomic's Avatar
Are you sure that front driver side fitting on the fuel rail will clear the alternator?
Old 10-31-2014, 08:54 AM
  #282
tempoffroad's Avatar
im going to guess it wont. I had to get a special 90* fitting to make it work.
Old 10-31-2014, 10:23 AM
  #283
AkSSS's Avatar
Same here on the alternator clearing.
Old 10-31-2014, 12:13 PM
  #284
idahoblkss's Avatar
Not sure yet but I do have a low profile end fitting on the fuel rail and my altinator is shaved already from when I had my FAST intake ,those have the same problem so I'm hoping the clearances are the same.
Old 11-01-2014, 12:20 AM
  #285
8 Second Truck Club
Blown06's Avatar
Pull the plastic cover off the alternator, clearance, then re-install.
Old 11-07-2014, 12:08 PM
  #286
idahoblkss's Avatar
has anybody ever drilled out the rear steam vents on heads that have them blocked off? my LSA heads appear to have the riveted shut and was wondering if i drilled it out if the rivet would fall apart sort of speak.
Old 11-28-2014, 05:22 PM
  #287
idahoblkss's Avatar
well got the motor dropped in and almost ready to fire it up.waiting on a fuel fitting for the front driver side fuel rail this holley intake put the fuel rail right behind the alt to where its not notch-able so i ordered a special 90 so hopefully it works. other then that just need to prime the motor and hook up the hot pipes and coils/plugs and she will be ready...
Old 11-28-2014, 11:20 PM
  #288
AkSSS's Avatar
Excited to hear this thing run!! I know you will have great success with this setup!!
Old 11-29-2014, 12:47 AM
  #289
8 Second Truck Club
Blown06's Avatar
9's at 140+ NOW DAMN IT!
Old 11-29-2014, 02:26 PM
  #290
idahoblkss's Avatar
the track is closed up here till spring but thats fine i really want to get the set up dialed in before i go anyway. what do you guys think my 126# injectors will be good for as far as HP / track times on e85 ? i got 2 450 pumps so i think i have plenty of pump but i know my injectors will tap out soon.
Quick Reply: potato land build, 9's@140+ is the goal
