Oakley's History Lesson and Build Thread
Old Oct 27, 2014 | 10:17 PM
  #781
Atomic's Avatar
I have a gauge for that
I dont drive often, and when i do it only gets in boost at the track
Old Oct 27, 2014 | 11:10 PM
  #782
oakley6575's Avatar
Yea I must put at least 200 miles on my truck a week when I'm not working on it. And I romp on it quite a bit. Mines not a race truck yet
Old Oct 28, 2014 | 02:51 AM
  #783
oakley6575's Avatar
I still have the tune on the rich side and am working out some of the little issues I'm seeing. Here is a 65-115mph pull on 15-16 lbs of boost at 17* of timing. IAT's went from 70 degrees to 88 degrees during the pull and I'm spraying meth after the IAT. Check out how hard the speedo is still pulling at 110+mph. Makes me think what it would run at the track at this level.
Old Oct 28, 2014 | 04:51 PM
  #784
69Camaro427's Avatar
Yeaaa Buddy!!! I don't think you are going to be able to break that 4.8L
Old Oct 28, 2014 | 07:11 PM
  #785
oakley6575's Avatar
Don't try and challenge me. Haha I'll be putting the radials on this week sometime and running 20psi through it. We'll see what happens. It was getting kind of scary last night downshifting into second at 16psi. It would walk for a sec and then grab hard. I think I have a vid of it spinning through second gear up to about 80mph
Old Oct 28, 2014 | 07:14 PM
  #786
BlackGMC's Avatar
Resident Retard
How is first gear with those radials? Still worthless?
Old Oct 28, 2014 | 08:04 PM
  #787
oakley6575's Avatar
They dead hook from a launch on the street but I haven't tried downshifting into first at like a 35 mph roll. Not sure if they would hold then or not. Really glad I went with 15's though.
Old Oct 28, 2014 | 08:07 PM
  #788
GMCtrk's Avatar
What PSI do you run them on the street? Dead hooking on the street is VERY impressive.
Old Oct 28, 2014 | 08:17 PM
  #789
oakley6575's Avatar
I think they were around 22psi when I was testing them out. I did a few 6psi launches and they spun only spun once but I stayed in the throttle and they grabbed and went. So I thought it must have just been some loose gravel I was on off the line.
I don't have the cubes you guys do so tq off the line isn't great. I need a converter change and/or trans brake
Old Oct 28, 2014 | 08:21 PM
  #790
GMCtrk's Avatar
I run mine at 35 psi on the street and they'll spin, but not nearly as early as the street tires were. Tire pressure is critical for the drag radials. I drove mine home 35 miles from the track on 15 psi and they were solid as a rock.
