Oakley's History Lesson and Build Thread
Old Sep 4, 2014 | 06:32 PM
  #661
Vortec350ss's Avatar
Originally Posted by GMCtrk
I have the NGK AFX wideband and their display only shows in the gasoline scale. So, when my gauge shows 14.6 I know that my true AFR is 9.8, given that I was running E85.
Now, only my EFI live scan tool, I have a PID set up to display the AFR in the E85 scale, so on there is does display the correct AFR. Regardless though, the AFR is not that important to me. Lambda is what I'm after. It would be nice if the gauge had the option to show in lambda, but either way its fine.
Thanks that's all I was asking for.
The thing that confuses me if why you say AFR is not important but lambda is. They are showing the same thing... one is just a multiple (by 14.7 on your gauge and by 9.8 in EFI). So in a way that statement is kind of contradictory.... and now I'm just being a pain in the ***. Please dont take that as me not knowing what lambda is
Old Sep 4, 2014 | 06:35 PM
  #662
oakley6575's Avatar
I was simply trying to ask if his gauge was showing him lambda (1) or Lambda on a scale of 9.76 for ethanol.
Here I fixed it for you:
I was simply trying to ask if his gauge was showing him lambda (1) or AFR on a scale of 9.76 for ethanol.
Lambda is lambda. Lambda is not AFR.
Old Sep 4, 2014 | 06:39 PM
  #663
oakley6575's Avatar
Originally Posted by Atomic
I am pretty sure it alternates which cylinders it cuts and can retard them all if needed. You are overthinking this. Set the rpm you want and let it do its job. If you arent building enough boost, set it higher or make sure your gate is staying closed.
How do I check to see if my wastegate is staying shut?
Old Sep 4, 2014 | 06:42 PM
  #664
GMCtrk's Avatar
Because converting what the gauge is showing to the actual AFR for ethanol is another calculation I have to do in my head on the fly. It would be much easier if it just showed lambda.
Old Sep 4, 2014 | 09:38 PM
  #665
Alright you got me there. I used the wrong word. But I know you knew what I meant.
Edit: and at the end of the day it really is a multiple of lambda, not a true AFR. For example I run pump 93 and both my gauge and HPT show AFR on the gasoline scale. My fuel is really e10. So the AFR I'm reading is false. It's a multiple of lambda on the gasoline scale, which I'm very used to and comfortable with, not true AFR.
Old Sep 4, 2014 | 09:46 PM
  #666
Atomic's Avatar
I have a gauge for that
What type of boost controller are you using? Most electronic ones have an open setting that they wont open the gate at all until that pressure is reached.
Old Sep 4, 2014 | 10:29 PM
  #667
oakley6575's Avatar
Alright you got me there. I used the wrong word. But I know you knew what I meant. Edit: and at the end of the day it really is a multiple of lambda, not a true AFR. For example I run pump 93 and both my gauge and HPT show AFR on the gasoline scale. My fuel is really e10. So the AFR I'm reading is false. It's a multiple of lambda on the gasoline scale, which I'm very used to and comfortable with, not true AFR.
Not sure what you mean by multiple of lambda. But if you are running E10 and want a true AFR reading, set up your HPT scanner to multiply lambda by 14.13. But it is much easier to just tune in lambda or a well known scale like gasoline.
Old Sep 4, 2014 | 10:32 PM
  #668
oakley6575's Avatar
Yea I think AEM calls it the crack pressure or something. I have it set correctly for my spring in the gate. But I think I am only running the 6lb spring. Would a stiffer spring help footbrake higher. I don't see why it would since the controller should add pressure to the top of the gate until the desired boost pressure is met. Or am I thinking about it wrong?
Old Sep 4, 2014 | 10:59 PM
  #669
GMCtrk's Avatar
The equation for your AFR calculation in the tuning software should take into account what fuel you are using. For example, I have PIDs for both E50 and E85.
Old Sep 5, 2014 | 12:00 AM
  #670
It means that to show gasoline AFR you literally multiply your lambda value by 14.7. Am I incorrect in assuming that?
When lambda is 1 my gauge will show 14.7. When lambda is .77 my gauge will show 11.3. Correct?? It's an exact multiple of lambda if that statement is true.
