Oakley's History Lesson and Build Thread
Old Feb 21, 2014 | 03:12 PM
  #431
Choda's Avatar
ouch... hopefully u like them
Old Feb 21, 2014 | 03:33 PM
  #432
MechE's Avatar
pics of the wheels?
Old Feb 21, 2014 | 03:42 PM
  #433
BlackGMC's Avatar
Resident Retard
Just got bent over at discount tire. $850 later and I have some heavy *** cragar drag wheels and 315/60-15 tires.
Should have bought some wheels like this. The wheels only weigh 22lb and they tuck and are cheap and are 16x8.5
Old Feb 21, 2014 | 07:06 PM
  #434
69Camaro427's Avatar
22lbs??? that's extremely light, do you know the weight with tire aired up?
4.10s skirrrrrtttt haha My favorite moto from pt "don't fear the gear"
Did you get the Holley manifold installed?
Old Feb 21, 2014 | 07:09 PM
  #435
After 6 months finally found the subscribe button
Old Feb 21, 2014 | 07:10 PM
  #436
oakley6575's Avatar
Originally Posted by MechE
pics of the wheels?
Just cragar 342 series. They were 159 each for the custom backspacing.
http://www.summitracing.com/search/p...-window-wheels
The problem was that I wanted to run a meaty tire. Something with a lot of sidewall and wide enough to put a fat mark on the ground. I also wanted to run a 30" diameter. So it came down to a 15" wheel, so I could run the 315/60 radials from hoosier or mickey thompson.
The track doesn't allow slicks, only DOT drag radials. So I was kind of stuck with the two tires I mentioned. I didn't think 159$ a wheel was bad so I'll give them a shot. Should be here in the next 4 weeks.
Old Feb 21, 2014 | 07:16 PM
  #437
oakley6575's Avatar
Got really tired of looking at a computer screen so I went out back and pulled the driveshaft out, rear wheels off, and pulled the diff cover. My 4.10's will be here sometime next week so I thought I would just tear it apart now and fix a few things.
A while ago, I put a line lock in my truck but once I got it installed and buttoned up, the damn solenoid didn't ever work. So since I'll be running at the track a lot now, I thought I'd either fix the line lock or get a replacement. I'll take that out of the truck tomorrow and see if I can get it to engage.
Those beefy tires and a good burnout with the line lock should give me decent traction with the new gears...I hope anyways. Next step is probably to relocate the shocks behind the rear end.
Old Feb 21, 2014 | 07:22 PM
  #438
oakley6575's Avatar
Hell no I still need to find a 04-06 fuel tank and order $400 worth of fuel fittings and hose before I can install the manifold. Should be fun as hell to get all that in at the same time and turn it up to 20+psi
Old Feb 21, 2014 | 07:26 PM
  #439
ShredSled's Avatar
What carrier is that, Eaton LSD?
Old Feb 21, 2014 | 07:28 PM
  #440
oakley6575's Avatar
No it's the cheaper version
It's just an auburn posi. It's taken a **** ton if abuse too. I'd buy another one in a heartbeat
