not a truck but it is a truck motor
Old Mar 8, 2009 | 11:24 AM
  #111
parish8's Avatar
single digit dreamer
you might be right but i see it more likely that the tranny went out and sent debri everywhere wich pluged up the cooler. the only thing that can plug the cooler is debri from the tranny. kind of the chicken or the egg debate.
Old Mar 8, 2009 | 11:49 AM
  #112
kbracing96's Avatar
Are you not worried about the Blowoff venting fuel and air out then it pops? Just a thought...
Old Mar 8, 2009 | 11:51 AM
  #113
Wilde Racing's Avatar
How do I change this text
Every once in a while it would make a noise while backing up after the over heat. Trans didnt actually let go until about 5 months later...
Reaction carrier planet died, lack of oil. Plates and disks looked good, trans was pretty clean.
Like I said, I'm the only one I've heard of, but I personally will never buy another aftermarket plate style cooler.
The car is BAD ***, got any more pics of the inside?
Old Mar 8, 2009 | 12:01 PM
  #114
parish8's Avatar
yeah, we could have planed that better but that is how it worked out. i have seen many alkey injection set ups that sprayed before the bov including my truck. there wont be a lot of fuel. i will let you know if it blows up.
we wanted to get a little fuel upstream of the intake to give it time to cool the charge air.
Old Mar 8, 2009 | 12:08 PM
  #115
Can you flip that pipe so the blow off valve is in front of the injector? Of course that is that much less time for the air/meth to mix and cool.
Old Mar 8, 2009 | 12:21 PM
  #116
parish8's Avatar
it would mess up the look if we did that. i am not too worried about it. it wont be spraying much meth at all. it will be all vapor and shut off as the tb is closing. considering the air will be hot and a large volume of it and just one injector i think the mixture will be real thin and not even visable when it blows off. those injectors will only be on above 5psi.
on the flip side if we see fuel spraying out when we let off then i will re work it.
Old Mar 15, 2009 | 01:35 PM
  #117
parish8's Avatar
got our first vid. nothing special, almost ready to drive >> http://www.neufamily.org/vids/novavids/1stnovavid.wmv
got some stickers on the car
Old Mar 15, 2009 | 01:48 PM
  #118
moregrip's Avatar
what a rush!
Originally Posted by parish8
Classic!
Old Mar 15, 2009 | 03:07 PM
  #119
kbracing96's Avatar
at least you got the most important part, the cup holder,
Old Mar 15, 2009 | 03:17 PM
  #120
TurboBerserker's Avatar
I AM A MOTHERF*CKER
That cup holder is probably worth .2 in the 1/4
